5th Gen Uconnect 12" Screen/Module, Premium Evic & Misc Parts
g00fy
Cummins 6.7
Got a bunch of Misc. items I've been accumulating since i got my truck, check them out and see if there's something you're after. All prices are OBO + shipping, all items are located in North NJ, so if you can pick up locally you can save the shipping.
1st Item, 2019 tradesman unpainted black tailgate latch with the button and bracket for the non surround camera does NOT have cutout for hitch light! $20 + Shipping.
2nd Item, 2021+ textured black tailgate latch with LED Light cutout, never used only test fitted, I purchased this by mistake and my camera did not fit, the camera hole was too small to fit the camera lens. $30 + Shipping.
3rd Item, Tan Overhead console/sunglasses holder/map lights/rear slider switch. LED bulbs pre installed in the map lights, has 1 broken mounting tab on the back, but it's ultimately held to the ceiling with screws anyway so the tab doesn't really make a difference in how securely it mounts. $25 + Shipping.
4th Item, 2019 Blind spot sensor modules and 1 heat sink. $75 $50 + Shipping
g00fy
g00fy
Cummins 6.7
Continued,
5th Item, TTPMS Module for UC4 Radios, Part# 68375990AC. $50 $40 + Shipping.
6th Item, UC4 12" screen for DIESEL trucks with Traction control button part#68477386AA. When I Retrofitted this into my truck I ran it for about a year or so before upgrading to a UC5 setup, I never took the factory screen protector off cause I'm weird like that, so the screen should be in brand new condition. $450 $400+ Shipping.
7th Item, UC4 12" MODULE w/video cable and anti theft code. There is 1 special side note with this item, I bought it from a salvage truck that must've gotten wrecked on a test drive because the Wi-Fi hotspot on it was activated and worked for free the entire time I owned it, I never registered the radio or paid for anything, so I don't know if it was still stuck in some sort of dealer Demo mode, it MAY still have free Wi-Fi hotspot, but I can't guarantee it. $450 + shipping.
8th Item, 2019 7" Premium Cluster / speedometer for 2500, 3500, 4500, 5500 Diesel trucks. Part#68361598AG, cluster mileage is somewhere in the mid 20,000's IIRC, but this can be adjusted to whatever you need if you have AlfaOBD. $450 $400 + Shipping.
g00fy
g00fy
Cummins 6.7
Continued,
9th Item, 2019 - 2020 Tailgate Harness, $10 + Shipping.
10th Item, 2019 2500 diesel 4x4 BCM, top mounting tabs are broken, part # 68372337AE. I don't know what this is worth, make me an offer.
11th Item, lower center console cubby thing with trim and USB hub & 110V outlet, $50 + Shipping.
12th Item, Upper Glovebox cubby thing with trim piece, one or 2 of the tab are broken on the the back of the actual cubby itself, $25 + shipping.
13th Item, center jump seat tradesman endcap, might come in handy if you are looking to do a center jump seat swap, $20 + Shipping.
Last Item I know of, 5th Gen ECODIESEL Premium 7" cluster part#68527343AE. I Purchased this by accident thinking it might work in my 2500 diesel, it did not. $300 $250 + Shipping.
g00fy
g00fy
Cummins 6.7
Reserved
Raming
California
Goofy, would that UC4 work in a 2023 Ram 1500 Hemi with the 5” screen?
g00fy
g00fy
Cummins 6.7
Don't know since they switched to Uconnect version 5 in the 2022 and newer.
g00fy
g00fy
Cummins 6.7
Bump for offers before I resort to FB marketplace
g00fy
g00fy
Cummins 6.7
Bump for a couple price drops
Sdpadrez
Any of the 12inch screens work in a 4th gen ram?
Inside Man
N.E. Ohio
Forgive me for my ignorance but what's the difference in that 12" screen between the diesel and the gas trucks. I'm looking for one, but my truck is a 19 2500 6.4?
g00fy
g00fy
Cummins 6.7
The Diesels have the Traction control button up by the hazard lights button.
MxChris
FL
Hey there, interested in the 12" screen and module. I have a 5.7L gas 2020 Tradesman with the 5". Other than the traction control being up top do you know if this combo will work for me? I can reroute the traction control or just leave it down below. Same question on those dash clusters, would love to get those three pieces from you in a package deal, not sure how to know for sure they'd work for me.
Thanks!
g00fy
g00fy
Cummins 6.7
Thanks!
The diesel clusters definitely won't work, as for the traction control button I have no idea, you're going to have to do some homework on that one.
MxChris
FL
Gotcha on the cluster. I didn't word my other question very well. I meant to say other than the traction control button being in a different place, do you think the control module and screen will work for my application?
g00fy
g00fy
Cummins 6.7
Other than the traction control everything else should work no problem, iirc that module actually came out of a 1500.
