I did mine a couple months back, wasn't too bad. At least once you figure out how to release the airbag clips.Installed some audio controls to my steering wheel that I bought off a member in the RF classified. Pretty straightforward and a really nice addition.
I bought the Lisle air bag tool and it made it pretty easy.I did mine a couple months back, wasn't too bad. At least once you figure out how to release the airbag clips.
I can't figure out how to reset my oil life indicator. I'll poke around tonight on the inter webs.
Thank you!Here's a video on how to do it
That's how you do it brother!!!Added Wilwood brakes. 6 piston front and 4 piston rear.
You can also turn the ignition to the run position,but don't start truck,and step on the gas pedal 3 times with-in roughly 10 seconds,turn ignition back off,and i usually open and close the door,that should reset the indicator.Thank you!
Gotta say the oil filter is in a rough spot. Gotta do something different next time.
Looks like a nice clean set up. I'll probably go this route next time.There's a plethora of variations of oil filter relocation setups available. Some are a direct bolt in, some are "universal" and require some knowledge to make your own (cut to fit) hoses.
I went to direct bolt it route with a PacBrake relocation kit. Makes oil changes completely mess free. I run the larger Mopar 899 filter so I go an even 8 quarts on oil changes now.
HP10595 Oil Filter Relocation Kit for 09-18 RAM 1500 / 19-23 1500 Classic 5.7L HEMI
Check out the deal on HP10595 Oil Filter Relocation Kit for 09-18 RAM 1500 / 19-23 1500 Classic 5.7L HEMI at Pacbrakepacbrake.com
