- Joined
- Nov 2, 2020
- Posts
- 10,338
- Reaction score
- 13,316
- Location
- El Cajon Calif. 92021
- Ram Year
- 2016
- Engine
- 3.0 ecodiesel
By the way, turn your front tires, until they just touch the inner fender
Then mark the contact area with some chalk or tire marker
then check the opposite side, mark it, if it needs it.
you have two choices, borrow a woman's hair dryer & hope they never find out, or buy a heat gun somewhere, Harbor Freight, for instance.
Then go some place like a thrift store & get a used 8" ? Metal bowl, or a short 3' 2 x 4 , your choice.
Heat up the marked area on the inner fender, it will not take much heat , then use the wood or metal to push delicately to reshape the inner fender , do everything in baby steps.
Likely you will have to turn your tires again, if more reshaping is necessary
Good Luck
Good Luck
