tgreen
- Joined
- Mar 11, 2024
- Posts
- 4
- Reaction score
- 0
- Location
- SHERWOOD PARK
- Ram Year
- 2019
- Engine
- 5.7L HEMI V8 with eTorque
Hey guys
Hoping this makes sense to someone. I've been googling some of these codes to see if there is a common denominator. Had a bunch of battery issues with the last cold snap here. The battery still tests ok, but on the lower end of the OK, so I just bought a new one. Using a BlueDriver to get the codes and clear them.
After having the battery off for 30 min and doing a Uconnect reset, I scanned to see what all in there. Not really noticing anything with the truck now, but I'd rather sort issues out at home than on the side of the road or in another city!
My codes:
3 Confirmed Code Code
U1514-87 Engine Controller Secret Code : Missing Message
B2303-13 Wiper Park Switch Input Circuit/Performance : Circuit Open
B2199-16 Battery Voltage : Circuit Voltage Below Threshold
2 Front Control Module (Central Gateway) Codes
2 Radio Frequency Hub Codes
B2199- 16 Battery Voltage : Circuit Voltage Below Threshold
U103C- 00 KIN/IGNM Communication : No Sub Type Information
3 Anti Lock Brakes Codes
C2100-16 Battery Voltage Low : Circuit Voltage Below Threshold
C2206-00 Vehicle Configuration Mismatch : No Sub Type Information
U0100-00 Lost Communication With ECM/PCM : No Sub Type Information
4 Electronic Shifter Module Codes
P1C8C-16 System Voltage : Circuit Voltage Below Threshold
P1C8B-16 Battery Voltage : Circuit Voltage Below Threshold
U145D-00 Implausible Data Received From TCM On D-PT : No Sub Type Information
U0402-00 Invalid Data Received From TCM : No Sub Type Information
4 Adaptive Cruise Control Codes
C2225-00 PCM Disabled ECU : No Sub Type Information
U141E-00 Implausible Data Received from Cruise Control Switch : No Sub Type Information
C2129-16 Battery Voltage : Circuit Voltage Below Threshold
1 Electric Power Steering Code
C212A-84 System Voltage : Signal Below Allowable Range
1 Parktronics Code
B210C-16 Battery Voltage Input Circuit/Performance : Circuit Voltage Below Threshold
1 Steering Column Control Module Code
B23A1-2A Flash to Pass/Optical Horn Switch Circuit Performance : Signal Stuck In Range
2 Air Suspension Control Module Codes
C1562-92 Ride Height Air Pump Control Circuit : Performance or Incorrect Operation
1 Powertrain Control Module Code
C0604 Active Air Dam Control Circuit Performance
1 Transmission Control Module Code
P1DF3-00 ECU Not Initialized : No Sub Type Information
2 Hybrid Control Processor Codes
U1818-00 Lost Communication With ECM/PCM on D-PT CAN : No Sub Type Information
Just seems like a lot is flagged out here and almost like the codes didn't clear maybe?
Most of this would probably make sense with the low voltage issues with the cold weather and a weak battery and like I said everything seems to be in working order.
Thanks in advance for any insight here!
My codes:
1 Parktronics Code
