dodge 1500
  1. A
    Eco diesel engine blown
    I have a 2016 ram 1500 ecodiesel. 120,000 miles. About a month ago I was going around a curve not even touching the throttle and started hearing a pound clanking noise. I got out to check things over and oil was dumping out of the bottom of the engine. Idk if it jumped time or threw a rod or...
  2. T
    Help with steering shake
    Hi guys, this is a question of what i need to do next to resolve this ongoing problem. my 2011 ram 1500 4.7l 4wd quad cab 6.5ft bed had some suspension work done around the middle of march and i have been fighting the problem since the suspension was redone. at around 65-75MPH the steering wheel...
  3. F
    new after market true LED headlights not fully working
    Hey, new to the site. Hopefully someone can aim me in the right direction. 2018 ram 1500 5.7 express DNA Motoring LED headlights. Right, I bought some true led headlights (full housing assembly) to replace my deer smashed headlights (LED is replacing halogen NON projector) The headlights...
  4. C
    06 Ram 1500 4.7 please help
    Ok here it is, I have an 06 Ram 1500 and the oil pump went out, causing it to overheat and blow a head gasket. As the truck has over 300k miles on it we opted to go for a rebuild versus a repair. Since then the mad scientist and I tore it apart and we have replaced the pistons, rings, entire...
  5. C
    Sluggish 02 dodge ram 1500 4.7L
    2002 3rd Gen 4.7L Dodge Ram 1500 SLT Quad Cab - Auto 4WD The truck has been running real sluggish. Shifts gears in high rpm's and has difficulty going up a very steep hill by my home. When going up the hill it won't go past 30mph. So far I've: Switched out all spark plugs and coil packs...
  6. E
    Rear end noise
    Hi everyone I have a 2009 Dodge Ram 1500 (4th Gen) 4X4 3.55 Rear End. Im experience a noise from under the truck and not sure what is making it. I ran truck with tires, brakes, rotors off and recorded a video of it. After this i removed driveshaft, pinion turns fine, can not feel any in/out...
  7. E
    2009 Dodge ram 1500 5.7 Operating Temp Issue
    2009 Dodge ram 1500 5.7 Having issue with truck getting to operator temperature. Truck would only get up to around 180-184 degrees F since i bought it in March of this year. Have replaced coolant temp sensor, and thermostat, used spill proof funnel on radiator to bleed any air out of system...
  8. A
    Check Engine light for active grill shutters, fan always on and loud
    Hey guys, I have a 2019 Dodge Ram with the 3.6l v6. I just woke up one morning to a check engine light. I had a computer hooked up to the obd and it threw a AGS (active grill shutter) code. I pulled everything apart and the AGS along with the whole aero system seemed to be perfectly fine. I...
rskew
