I noticed a strange waviness in the reverse lighting as seen through the backup camera. As I was backing up in a parking lot a bystander told me there was water in my reverse lights. The water caused one of the bulbs to break. Has anyone else ever had this happen? Does anyone know how the water...
I have a 2016 Ram 1500 Longhorn. I am replacing my backup lights with LED and just noticed that both the backup lights (right and left side) don't work. Both of the bulbs are still good but they just don't turn on. I tried installing one of the LED bulbs and that doesn't work either. Then tried...
I've been searching for days on how I would wire up my BD S2 backup lights to both my reverse lights and also an upfitter. The outcome im looking for is to have the extra lights come on when I shift into reverse as well as by themselves while in park with the press of one of the stock upfitter...
I have a 2010 dodge ram 1500, 5.7 Hemi, and automatic transmission. Also tow package and both 7 pin and 4 pin connections, (Read on to see why I'm including tow info).
About a year ago the reverse lights started occasionally staying on. I would disconnect the battery for a bit then reconnect it...
Purchased these this summer and never installed because I decided to go a different direction with my rear bumper lighting. New never installed or used.
Purchased for $120 from Rough Country...
Slowly but surely, I am progressing to all LED lights in my 2018 2500! This video shows how to upgrade your reverse light bulbs with LEDs. The LEDs used are much brighter, thus more people WILL stop to allow you to backup (if you park front facing in). These lights are bright, and prove their...
I can't find anything that tells where the backup light switch for an automatic transmission is located. Is it the same as on a manual transmission? Bulbs and fuse are good so trying to check the switch that turns them on.
Any ideas??
