Something weird with turn signal
Blue Chaos
Bloomington, IN
LA 318
So my turn signals work fine when my parking/headlights are off. But if I have my park/headlights on my passenger side signals work fine but my driver side the light on the cluster just stays lit and both front and back bulbs shut off completely. I thought it was a bulb problem so I replaced them all. Still having the same issue. When the parking/headlights are on but no turn signal they work fine. When they are off turn signal works fine, but not together... Please someone tell me you have had this happen and its not a whole wiring harness.
crazzywolfie
under the truck
there is most likely a short in that side or a bad bulb. usually my truck does that when the park like is out.
B
Blue Chaos
Bloomington, IN
LA 318
My connectors are in ROUGH shape, could that be it? The rear where it grabs the bulb is fine but the wings that hold it in the new tail light are rusted off. The front one half or the metal part that holds the bulb is rusted off. I had to scrub the inside connectors just to get the bulb to work.
crazzywolfie
under the truck
the issue will be in the front somewhere on the side that the light says. it could be a connector or socket. would really be hard to say without being there. the turn signal indicators are tied to the front turn signal wiring which is why it comes on when it is out or there is a issue.
B
Blue Chaos
Bloomington, IN
LA 318
Awesome! Good to know! I will begin with a new connector and then go on a wire hunt.
crazzywolfie
under the truck
ya. it took me a bit to realize it on my truck. also did you also check the turn signal bulb on the light in the fender? could also maybe cause it to kick on.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Also check the hazard switch...when they go bad, weird things happen
B
Blue Chaos
Bloomington, IN
LA 318
I pulled the little reflector bulb or whatever just to make sure it wasn't it. No dice again. And with the hazard switch. I pulled it and they work fine, but if that's the problem, do I just replace the switch??
crazzywolfie
under the truck
the switch is not likely the issue. your issue is still probably still under the hood in the wiring or connectors. somewhere power is getting from the park lights into the turn signal light system
The War Wagon
da' 'BURGH
318 Magnum
This. I've had some insulation rub away on socket wires, and a little duct tape fixed that (electrical tape exposed to the elements rarely stays put). I also had to clean out a turn signal socket with some steel wool, to remove the corrosion, and make a good contact.
The front end of our RC's catch/caught a LOTTA salt in the face back in the day, so don't be surprised to find worn insulation and corroded sockets that will take a Dodge SHERLOCK to track down. My horn wiring is practically shot, and needs to be redone next.
B
Blue Chaos
Bloomington, IN
LA 318
Yeah my horn wiring is virtually non-existant. The turn/parking connectors are completely and utterly screwed. They are only half there. So I'll get ahold of my parts guy for some new
crazzywolfie
under the truck
ya if the connectors are toast you are probably best to just remove them and connect new light sockets straight to the wiring an use some dual wall heat shrink tubing to seal it all up
B
Blue Chaos
Bloomington, IN
LA 318
Put in new sockets on all for corners. Fixed some of the problems. Traced the wires and found one of the grounds was broken. Fixed that and they all work perfectly now! I think I will write up a how to with pics. I took a lot lol
crazzywolfie
under the truck
that is good to hear. a bad ground would have also cause the issue but not really as common to think of. usually it should have also cause other issues like the 1 headlight to be a bit dimmer or something since the headlights would share a ground with the turn signal but i guess the old sockets could have also been part of the issue.
crazzywolfie
under the truck
seen that before. my 91 was like that on all sockets. i don't think my 81 was that bad but i think i ended up replacing all the sockets on it just because they were not looking great.
B
Blue Chaos
Bloomington, IN
LA 318
My driver side front and rear looked like this but the passenger side wasn't bad but I replaced them anyways. This was the rear one lol the wings completely rusted off lol
crazzywolfie
under the truck
ya not too surprising. i think i actually have or had a light socket with less than less than that left of it. on my 91 the previous owner had just taped the sockets into the housing. also i don't know if you replaced the reverse light sockets or not but when i did i used turn signal sockets so that i would only have to keep 1157 bulbs on hand instead of having to keep a couple 1156 bulbs kicking around.
B
Blue Chaos
Bloomington, IN
LA 318
I thought about it. But I am out of cash lol. The three wire (1157) sockets were actually cheaper than the two wire (1156) sockets. I may go that route.
therapywolf
