reb0957
just to be sure I am clear. If I want to run my tires at 60, set step 1 at 60 and step 2 at 50
Thanks
Thanks
If you plan to run 10 psi difference. I suggest your "setting" be in the middle of the high and low just to give you a little cushion.
When following the prompts - when asked for desired pressure setting - set new pressure levels.
You do not need to replace anything - just perform the function to set new levels.
Anyone know of a dealer in Minnesota that can handle the tpms reset for a 2015 RAM 2500,Ben to 3 said that they can't find it on there software and will have to wait for update???
