Alignment "issue"
tommyboi87
houma louisiana
5.2 Magnum
All I did was install shorter springs. No drop spindles or anything special. With the 4" drop in the front, I've got a really noticeable amount of camber that's affecting my steering a little.
Sent from my SAMSUNG-SM-G925A using Tapatalk
tommyboi87
houma louisiana
5.2 Magnum
So when I lengthen the slots, would I lengthen towards the inside of the frame or would I lengthen it to the outside frame?
HeavyD
Medicine Hat, Alberta - Canada
4.7 SOHC 5 SP Auto
Towards the tire.
First thing is to loosen the camber bolts & pull the tire (a-arm) out as much as you can, & then see how much more you need toooo.
check out the tread I made about the way I fixed mine.
http://www.ramforum.com/f46/tire_lean_after_drop-66988/
tommyboi87
houma louisiana
5.2 Magnum
Great write up man. Love the pictures. You have a third generation though. Does that apply to 2nd Gen too?
HeavyD
4.7 SOHC 5 SP Auto
does not look like it, your mounts are diff, I should have looked that up.
how much material do you have from where the holes are towards the tires?
tommyboi87
houma louisiana
5.2 Magnum
Enough to take about 5/16 or so. Maybe not that much.
tommyboi87
houma louisiana
5.2 Magnum
Yea, at max, I still have maybe a bit over 2 degrees of camber.
tommyboi87
houma louisiana
5.2 Magnum
What do you want to see? The camber angle of my tires, or the pivot bolt slots?
tommyboi87
houma louisiana
5.2 Magnum
I'll get you a pic tomorrow. It's almost dark now. I don't think the angle would show up that good
tommyboi87
houma louisiana
5.2 Magnum
Overhead and front views buddy.
tommyboi87
houma louisiana
5.2 Magnum
I'll try to get some better pics tomorrow. I back in where I live and for some reason, it seems like my camber is reduced when I back up.
Bobram1500
