HID problems.
pavester
texas
okay so i got a set of retro lights and HIDs from jeremy. they are 6Ks.
fast forward to last week, i get a set of 10k HID lights off my buddy for super cheap since he did a front end conversion.
I install the 10Ks in my truck, and one side is flickering on and off. Im trouble shooting and remember the lights from jeremy. I run inside and pull a ballast of a set of the 6K lights.
Take it outside and plug it up to the side that wouldnt stay on. BOOMSTICK they both start working perfectly.
Now the problem is the side with the OG ballast is the correct 10K color and has that blue tint to it. and the side with the 10K bulb and jeremys ballast from a set of 6K lights is a very noticable different shade.
any ideas what could be causing this??
pics:
both bulbs are 10k,ballast on the right is the one that came with the 10k bulbs. ballast on the left is from the 6k kit out of jeremys retrofits
right light
left light:
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I had HID's in my Durango and will never do them again. I love the output but even when done correctly far less reliable than a halogen setup at least here where the winters seems to really be an issue with them. I found the flickering did not occur when I ran a lead directly to the battery. They later stopped working though like the original ones and I ended up just pulling them and going back to the stock ones right before I traded it on my Ram. I am a rare breed as I prefer the true white of 6k over the 10k.
pavester
pavester
texas
ya i am just waiting to get time to perform surgery on the set of projectors i have from jeremy... or just sell them altogether
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Are those Rus's old set?
I would be willing to bet that the ballasts you have from your friend aren't putting out a true 35W, where the ones Rus had do, which can cause a difference in the color output you are seeing.
pavester
pavester
texas
yep i am using a ballast of the set of projectors i got off here.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
The fun part with those, I got them from my old supplier - who I chucked after that set. I hated that the wiring he sent wasn't "right". I don't think he understood what was needed for a Dodge Ram.
Damn.......so much has changed since then! Holy cow........
Yeah, all I can think of off the top of my head is that its pushing more power. I could be wrong, I'm not an electrical guru! :D
