Gearing
busse
Iowa
5.9 magnum
What all do you need to replace if you want to go from 3.55 to 3.73 gears
ramburger
find a local gear installer
mitchbowers
Ohio
1996 2500 5-speed, soon to be leveled on 33's
5.9 Magnum
Unless you have a Dana, there are no 3.73s
which to be clear, in case there was confusion on OP's part, half tons have a Dana 44 and a Chrysler 9.25 in the rear. so you'd be able to go to a 4:10 ratio.
Sent from my A0001 using Tapatalk
dapepper9
Iowa/Nebraska Border
5.9L V8
2500s you can get 3.73s. 1500s no better to go with 4.10s. Will cost the same but do way more for you
Gr8bawana
6.7 CTD
Did this with my 1500 4x4. 4:10 and an Auburn Gear torque sensing differential for the rear. It was just over $1200 at 4Wheel parts installed since I don't have the needed tools for gear set-up. It was quite an improvement going from 3:54 ratio to 4:10.
Eddo
