Bulkhead connector isnt matching up at all with diagram
bcurtispt
318 2Bbl
I've been doing some major wire repair to an 84 w150. I've made my way back to the bulkhead connector. Now that I'm here I'm looking at the various wires going into it and they're not matching up with the wiring diagram from the haynes manual. I'm currently working on #23 in the connector diagram and there's nothing there at all as shown in the attached pictures. Instead that wire is running into #5... how should I proceed?
Am I taking crazy pills or just reading this wrong
crazzywolfie
under the truck
i think your looking at things backwards. that wire that you think is number 5 is actually number 2
this is how you want to be looking at it
B
bcurtispt
318 2Bbl
That makes much more sense!!! Thank you so much!! Why do they illustrate it like that?
crazzywolfie
under the truck
the one you posted is a pic of it looking at the connector from in the cab. both are important depending on which side you are looking at it from.
B
bcurtispt
318 2Bbl
Crazy one last thing on wiring: does this connection use a connector of some kind or can I solder it together?
It's the only connection like thay I've encountered during rewiring with 4 different wires and 3 different gauges
crazzywolfie
under the truck
from the factory i think that connection is crimped together and then soldered like many others but i never checked when i removed it from my truck. i upgraded to a power distribution center so i didn't need it any more
B
bcurtispt
318 2Bbl
Do you have a picture/parts of your setup?
crazzywolfie
under the truck
i got my power distribution center out of a 2000 caravan and made it work with my truck. it is not pretty but it works for what i want it to. i wouldn't mind eventually hooking more up to it but haven't wanted to hack up my harness to do so.
B
bcurtispt
318 2Bbl
Oh dear god... I thought the stock diagram was bad. Could I continue to use your wisdom in identifying the two items circled? The R6D-10bk at the bottom looKS like it goes over to the next page but it doesnt... also I couldn't find the top connections?
HLfAwNI
1Popeye
