automatic car wash- will it scratch
Hemipower95
Will an automatic car wash scratch my paint? (Its a new truck)I like to wash by hand, but my truck picks up dirt really fast, and i like to have it clean. I know it might not make a really noticeable scratch, but just wondering.
sbarron
Wasilla, Alaska
I like to wash by hand as well, but in Alaska in the winter that's not an option. Go to a touchless and you'll be fine.
Mineralram
Stay out of the scratch and dent washes, i wash by hand or only go thru touchless washes
Sent from my SM-G900W8 using Tapatalk
Farmer Fran
Earth
2020 Limited Loaded - Sold
Go Touchless and you will be fine...
Problems I have noticed (at least in my area)...
-The "special wax/polishes" they put on the truck might mess with your auto wipers (if you have them)
-They do not do a great job only a decent job. I have tried 5 in my area only only 1 is remotely worth it
-I love the under carriage blast for removing road salt and debris, especially before an oil change.
Brian_Ram
More than likely it will not scratch your paint. However, it will scratch your clear coat. Even hand washing can do that. That's what swirls are. I am pretty meticulous about how I wash and wax my vehicles. Hand wash and a good sealant before winter. If I cant hand wash in the winter I only use touchless washes with undercarriage but no polish or wax.
BigRed4x4
Mid Michigan
Always touchless. The only do it yourself car wash within 15 miles of me ends up costing me $10.00 at minimum and that's when I'm rushing so I don't run out of time. I swear 1 minute is more like 30-40 seconds.
9 out of 10 times I wash by hand in the summer. The closest gas station gives you .10 off a gallon of gas when you buy a car wash so I look at like it's a win win during the winter.
RAMblin1217
It won't scratch the paint but will leave swirl marks like crazy. If you have a machine polisher, then do it at risk and fix the swirls when it warms up. I will never take my vehicles through them, especially after seeing the way the previous owner of my truck treated it...worst swirls ever.
7777xm
Covington, GA
I've never really had issues with automatic car washes. Over time, they may leave swirl marks, but you see that on 99% of the cars out there. There's a few here that are pretty **** about their swirl marks but most of us have them.
One thing I recommend doing before going through the automatic car washes is beef up your third brake light gasket. I have a theory that people that use automatic car washes or pressure washers destroy the OEM junk gasket and could lead to water leaks down the road.
Sent from my SM-N920T using Tapatalk
RodRam
Ga.
touchless only works to blow the big dirt off, when your done the road film from raining is still there I also found the high price touchless put some kind of wax crap liquid on that makes my windshield look filmy at night if raining, I'm done if I go now its just the cheap wash with no wax. I might run thru a regular wash at some point.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
I refer to the drive thru car washes as "tunnels of destruction". A touchless is the most preferred if you have to use a car wash, but the ones with the brushes will, without a doubt leave swirls and some small scratches in your finish. You can "correct" your paint by using a polish and an orbital buffer before you seal and wax again. I understand that some circumstances can't be helped, but just realize that anytime you have a brush rotate on your paint, it's going to leave either swirls or scratches. There are some really really soft type brushes but I don't think you will find them in a commercial car wash.
Jay
xrsman
Ontario
3.0 Ecodiesel
I wish I could go through touchless..lifted truck probs lol
Sent from my SM-G920W8 using Tapatalk
Informal
SoCal
2015 Sport 4x4
Touchless carwashes are only good for getting the first layer or two of mud off, which makes washing your driveway off easier when you give it a proper bath.
YMMV
THETANK
up jor *** mang
2015 R/T
I am allergic to any carwash other than me doing it by hand, oh so are my vehicles. My wife's vehicles, well that is another story.
02Steve15
Connecticut
I power wash the under carriage in the winter then i run it through the car wash once a week. Ill wax it in the spring which will take car of the swirls. I care more about the underbody in the winter so im not so picky about the body until spring and summer. In the summer i wash it by hand.
atc06jh
Middle Georgia
I've seen car washes fade door handles on other cars before. Some friends worked at one while in high school and used it like 3 times a week and their handles were black...ended up bluish.
Andy578
Ontario, Canada
2014 Outdoorsman
those touchless washers never seem to get my rims clean.anyone else have that problem?
they seem to have issues with trucks. always missing the wheels and parts of the tailgate as well as the rear window. i just assume it's because they are designed with cars in mind
BigA
Ohio
5.7 Hemi Etorque
Hand wash only for my truck. I don't want any more swirl marks then necessary on my black paint, plus I'm not found of the heavy duty detergents they use which is hard on everything and can dull headlight lenses and everything else. During winter we usually get a warm enough day like 30 degrees or warmer and I take a warm bucket of water to the do it yourself car wash which also has heated water.
BlueRT
Ohio
I blast off the worst at the quarter do it yourself car wash in the winter when above freezing. Then I take it straight home and do a 2 bucket rinseless wash in the garage.
radikio
