jadocs
- Mar 23, 2014
- 689
- 140
- 2014
- 6.7
Watch out... next thing you will be doing is contacting XForce amps and picking up a 4 pill to push with the President. Then you will be using the 4 pill to drive an 8 or 10 pill amp while trying to figure out how to add a couple 200A alternators to power it all. And then you think you need a base at the house as well but there you end up running 2 antennas. The first is a 10 element beam on a massive antenna turner and the other a 24ft groundplane for local chatter. This of course is all driven by a RCI 2995 that has been peaked, tuned, converted and has the power supply upgraded as well. This drives about 250 watts into an 8 pill base amp putting out a touch north of 2 kw. But this is just to drive the 220 vac powered broadcast steel triad tube amp that you try and tell everyone that it's a couple hundred watts but is hovering around 12kw and dimms the lights in the neighborhood as well as turns on touchlamps in every house for 5 square miles.
Just do me a favor... when this happens don't get digital echo, sound effects, and keep your damn roger beep off!
Sent directly from my thoughts using tinfoil antennas and a stainless mixing bowl helmet.
X-Force you say? Lol
Your absolutely right man. No echo or roger beep for me (even though the radio has it built in). I prefer full modulation. Noise toys are ***. Right again about wanting a base station lol
