Laramie Interior Handles
DARKNHT
Georgetown, IL
I took some pics of my Laramie door to show you guys what you're getting. I have the picks in my phone and I can't find the thread with the new Tapatalk format so I'll have to make this cheesy post first so i can find it in notifications. grrr
Okay the mood lighting comes from two [emoji111] places in the door. Behind the handle and above the storage pocket glowing down into the pocket. It looks like a cut out in the back of the door handle and there's a plastic clear lens with a dim blue light behind it. For the storage pocket, it runs the length of the door. 62df5fd8f8f11b5e9c734c992b5bc7c6.jpg2f726654d3c051a1883ac8d18cbb7ccc.jpg812650cf2f9049666a630770528fe92b.jpg29fc9b4675ed00802a39ff739be9aead.jpgf97edf9a37832bf9605c5acf130d6a08.jpge51c97a81cc6df5652bb9ea93a9d50a8.jpg
The last two [emoji111] pics is for the pocket and to get the light I put my phone in the pocket and pointed the camera up.
This is awesome, but any chances you'd remove the panels and show that they plug into and any module pn's?
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
If the plug is there for the light on the door card and not in the harness of a sub-Laramie you could tie in to the footwell light harness and run your own wire to the door cards.
BlownGP
Houston/Baton Rouge
So what kinda light is behind there?
Doesnt look like just one LED. Maybe a super bright one focused in those two spots
Birddog
West Palm Beach, FL
2016 Bright White 3500 Laramie 4X4 Long Bed
6.7 Cummins TD, 3.73
Unfortunately I am the sole caretaker of twin 2 year olds while my wife is out of state taking care of her sick grandfather. If it were something I could do really quick I would consider it but I can't. What I can say about it is it does not look like one bright light, it just looks like one regular led light that shines into the clear lens and the glow of it likes the Door. Like optic cable passes light. At most there's one light on each end of the clear tube for the back door and probably just one light that lights up the door handle. My best bet is that it's not an accessory that you can add but part of the Laramie door package when they install it it probably comes as one unit with the door interior. I really don't know if they can sell the part because it may not come separate from the door panel. They may just sell a replacement LED bulb. Then again my wife tells me I'm wrong all the time.
Sent from my SM-N910T using Tapatalk
Birddog
West Palm Beach, FL
On second thought, you could probably achieve the same glowing light if you just grinded out a section of the plastic and installed an LED strip light behind the hole. I'm sure you could certainly get a 12 volt power source in there.
Ram Man
FL
2013 Sport
It looks like maybe the black piece that surrounds the door handle can be swapped out and then run the wires on our own.
The trick would be to find the pn for this and someone try it
SitKneelBend
St. Louis
3.6 Pentastar
I just ordered some on Sunday. I'll post here if they are the lighted handles. Note that the standard Express bezels are NOT interchangeable with higher trims...
Ram Man
FL
2013 Sport
The sport and laramie bezels are definitely the same shape.
I am going to get a part number for the bezel with led and swap them out.
The lights in the doors are on with the headlights correct?
Tying into the footwells would only turn them on when the doors are open There's other options for wiring though so thats not a concern
BlownGP
Houston/Baton Rouge
No big deal. Was just curious. I think it's cool, but Have enough lights going for now. LOL.
Ram Man
FL
2013 Sport
Here are the available part numbers for the bezels with LED
Left Black 1WD61DX9AC
Right Black 1WD60DX9AC
Left Brown 1WD61LU7AC
Right Brown 1WD60LU7AC
These are the same for the rear as well except they do not offer Brown in the rear for some reason, Perhaps that area of the panel is black on all of them.
-Benny
Progress!
SitKneelBend
St. Louis
3.6 Pentastar
I ordered the LA8 color code. I can let you all know when they arrive if they include the LED. I doubt it because they only cost $12.
Ram Man
FL
2013 Sport
Let us know. The ones that I just posted are $60 each.
SitKneelBend
St. Louis
3.6 Pentastar
Ok, those appear to be the "premium" part number.
You will also need the screw covers if you don't already have them
1WD62LA8AA COVER-RELEASE HANDLE BEZEL
1WD63LA8AA COVER-RELEASE HANDLE BEZEL
In the above numbers, change LA8 to DX9 for black instead of diesel grey screw covers.
The non-lighted (cheaper) part number appears to be
1WD58LA8AC BEZEL-RELEASE HANDLE
1WD59LA8AC BEZEL-RELEASE HANDLE
Ram Man
FL
2013 Sport
Anyone have any clue what wire I should tap into on the driver's side to have these light up with headlights/interior gauges?
Uaintlo
waiting for updates on this!
Ram Man
FL
2013 Sport
bump. Not sure what wires to tie into on drivers side or passenger side so these will stay lit up only with interior gauges/headlights
SitKneelBend
St. Louis
3.6 Pentastar
There's a power line for the lights in the door controls. I'm sure that could work although I'd be weary of them.
Ram Man
FL
2013 Sport
thats not a bad idea, idk why I was over thinking it...
Ram Man
FL
2013 Sport
EDIT:
Updates coming soon!
txram956
