2002 ram fuse box wiring/ fuse #51 help please...
Sohc1997
5.9L
I just purchased a 2002 ram 1500 quad 5.9 4x4, no power to anything with key off. I Checked all fuses, pulled every plug from fuse box and clean the pins. Looked at wire harness and can't figure it out. Fuse 51 is good, I've search for 2 weeks and can't figure it out, there is also no radio or power to obd port for scanning. Any advice would be appreciated, thanks.
S
Sohc1997
5.9L
Well I figured it out, the pink wire in pin #16 obd port is the power lead witch ties into everything for fuse #51. That wire is #9 in the green plug for fuse box, it's was corroded and broke off the pin. All is good now!
justin13703
MD
Good work finding that, problems like that can be a nightmare
Hot Ducer
Atlanta Ga
Right and thanks for posting your results!
2003 1500 QuadCab 5.7 4x4
TemagamiRick
Magnum 4.7
Thank you so much for posting. Same problem has been driving me crazy all summer.
2004 1500 SLT QuadCab 4.7 4x4
Sent from my LG-D852 using Tapatalk
VLG6963
