Should I?
usaf2006
Augusta, GA
Since you plan to lift in the future, buy some bilstein 5100 adjustable shocks. They're about $100 each but will level the truck and go well with a lift kit in the future.
C
Colin_5.7
Will I be able to lower it with those?
usaf2006
Augusta, GA
Oh, I thought you said you'd level it, meaning lift the front an inch or two. No you can't lower with them.
Bullitt5339
St Pauls, NC
But how much better did that $90 make it? Now you can charge others since you already have the bit haha
I will let you know how big of a difference it makes, but based on experiences with other cars and trucks, the closer you can get the tie rods to level, the better off you are. The Ram has by far the most violent bump steer I've ever had, normally on other cars, you hardly feel it on normal bumps.
1Popeye
