96 Horn Problem
pstan13
Cummins
One of the horn buttons stuck down and the horn finally stopped when it burned out the fuse in the relay box. Can the button be fixed or be replaced? If it can be replaced, how do I get it out of the steering wheel?
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
stuck button I would pry out with a screwdriver and not use that button again. Also you could by pass and install a button on the dash if need be.
Gr8bawana
6.7 CTD
I had the same problem. I just unplugged the wire at the horn but of course now I can't honk the horn at A-hole drivers.
