Truck starts then dies
BoomerRam
Yukon, ok
I have a 2011 ram 1500 outdoorsman. today my truck started being a pain in my a$$. I would start, let me drive and then die while driving. now it starts then immediately dies. I'm thinking it's the wireless ignition node. thoughts, tips, or advice would be greatly appreciated!
Burla
2010 Hemi Reg Cab 4x4
Either losing spark, gas or air. Something in ignition or gas filter clogged maybe. if it was something like a sensor protecting the engine you would likely be getting a code.
BoomerRam
BoomerRam
Yukon, ok
thank you for the idea. I will check my plugs tomorrow.
Burla
It's not your plugs.
Rampant
NJ
392 Hemi
Need more info. How does it start? i.e., barely starts after cranking for 10 seconds, starts normal, etc. Also, when it dies, does it spit, buck & sputter or just cut off? If it's immediate, it's likely electrical. If it's more predictable and depends on certain factors, it's likely a fuel and/or air problem. Any codes?
gisboro
South Carolina
Crankshaft position sensor will do what you are describing and wont always throw a code if at all.
Burla
the fuel filter is new
New as in you just put it on then you started having issues? If so, I would look there first, could be defective.
BoomerRam
BoomerRam
Yukon, ok
new as in been on there for a little over a month with no issues.
BoomerRam
BoomerRam
Yukon, ok
sorry I should have been more specific. I started having the typical starting issue I have read about on here with is why it led me to think the win is going out. it will start and immediately die. I got it to start and run just long enough to back it into my garage. then it died again.
nickpohlaandp
Lake Charles, LA
Try shooting it. I once had an old horse and I asked my dad what to do. He told me to shoot it... so I did. After that I had an old horse with a bullet hole in it. I'm not sure what good it did, but I'm just passing along my dads advice.
Rampant
NJ
392 Hemi
I'd go through that fuel system with a fine-tooth comb first. Change filter. I know its not old, but just rule it out. Check fuel pump pressure and go from there.
T-Revs
North New Jersey
2014 Dodge Ram 1500
Any possibility on codes? It'll be a big help in figurin this out before shotgun it. If it were a WIN module, you wouldnt be able to start the truck. These keys are that sensitive to them. Would even throw an error on dash saying "BAD KEY"
BoomerRam
BoomerRam
Yukon, ok
no codes at all. no check engine, warnings, or anything else. it started with me having to turn my key very slow to basically find a sweet spot so my truck would start.
nickpohlaandp
Lake Charles, LA
When did Ram go to using the key fobs? Do you have a regular key? A long time ago, my ex-wife's Prelude started acting funny on startup, then gradually over time the driveability fell off, and finally one day it died and wouldn't start. It ended up being the ignition switch in the column. The guy who did the work was a Honda expert and he told me it was actually a common problem on Hondas, but I imagine it could be a similar issue with other manufactures as well.
XCELLR8
Central Illinois
Get a fuel pressure gage and check the pressure, both with the key on and during cranking. Compaire it to the factory specs.
BoomerRam
BoomerRam
Yukon, ok
the issue has to do with getting it to crank. when it cranks it will fire right up, no hesitation. but then immediately dies. my trunk won't just crank over when I turn the fob. I have to slowly turn my fob and hit a certain spot to even get it to crank.
am3334
