analog56x
- Aug 18, 2015
- 4
- 0
- 2011
- Hemi 5.7
95 46RE wiring hacked...
Well, i just bought a 95 RCSB 2wd 318 auto. I drove it 5 minutes to my house and noticed that it was hesitating really bad while trying to go from a stop. I thought it was a fuel issue, but today, i was backing up, and noticed that it doesnt bog at all. I could do a burnout in reverse if i wanted to...
so i remember from my previous job about transmissions, and i have figured out that my truck, when in drive, is starting off in 3rd gear. I key on/off/on/off etc to get codes, and i have the following:
37: trans converter solenoid (this code flashed twice in a row...)
45: trans overdrive
32: egr
So i got under it and noticed that 3 wires out of my 8 wire harness are cut and folded back on themselves...
The 3 wires that arent connected are:
Violet/wht: governor pressure solenoid control
Orange: 5v supply
Red: transmission control relay output
So, i tried digging through my conduit to see where these wires were cut back to, and... they arent... those 3 wires just arent there... i traced the conduit up to the T under the wiper cowl, and there are no cut wires... i have no freaking idea where to go from here...
Im also missing a pigtail that plugs into a 2 pin sensor or something on the bottom drivers side of the transmission between the pan and the trans mount...
I will get some pictures here in a sec. I really need some help, so thank you in advance!
45: trans overdrive
32: egr
Orange: 5v supply
