Wider tires on stock rims
Up State NY
I have a 2012 3500 Limited with only 28000 miles on it and want to get rid of the Firestones that came on the truck, they are the worst tire I have ever owned. I'm looking at BFG's AT / K02'S Michelin LTX AT2's and the Goodyear silent Armor Pro's. I pull a 35ft 5th wheel and would like to go a up to a 275/70/17 or maybe even a 285/70/17. I know the 275/70/17 will fit on the stock rims but what about the 285's will the fit my stock rims. Has anyone gone up in size with the stock rims ? If you have was there any issues towing ? Thanks for any feed back.
MADDOG
Out Exploring Arizona
Make sure the tire you pick is at least a Load Range E tire. A 275/70 will definitely fit with no problem.
The 285 should also fit but I'd check the tire mfgr's recommendation on rim width just to make sure.
Power247
High Point, NC
6.4 HEMI
I run 305/70/17s on the factory polished aluminum rims on my '12. I have had them on about 30k miles and no issues towing our 35 TT. They do rub a little bit on the pass side at full lock and articulation but no rubbing at all during normal/aggressive driving. 285/70s will fit no problem. That is what come stock on the Power Wagons of the same year.
Greg
2012 | RAM 2500 | CCSB | Custom tuned by Double R Diesel
2016 | Heartland Pioneer | DS310
