Bearings or the CV?
AustinB
Banned
San Diego, Left Coast
2015, 1500, 4x4, 40k miles
Slight clicking noise around 1-5 mph, squeak with wheel spin from 5-10mpg, and a faint vibration noise at higher speeds (almost sounds like using brakes with no pads).
sbarron
Wasilla, Alaska
both? lol
one good thing about changing the CV, you're already there to change the bearing.
AustinB
AustinB
Banned
Getting mixed answers.. didn't really pay attention when I had it apart a year ago..
Are these the sealed hubs or can you just replace the bearings?
Done with this ifs stuff.
DannyMK2
Long Island, NY
2015 Power Wagon
the hubs are sealed. clicking noise i would probably suspect a cv joint. check the wheel bearings for play to be sure, its easy enough to do.
AustinB
AustinB
Banned
Actually, after getting the truck in the air... the problem is in my right rear.
The wheel wobble under acceleration, including the rotor. The wheel was removed and put on a balancer, it's not bent. I don't have any vibrations or noises from braking so I guess that would cancel out the rotor..
My guess is a bent axle??!
kg93
AZ
did you at least check the rotor? Id think that a bent axle would cause a little bit more vibration then a slightly warped rotor
pickupman66
Tennessee
my front bearings made a clicking noise when I spun the wheel in the air.
AustinB
AustinB
Banned
Its definitely not the wheel or the rotor.
And the bearing is definitely shot...but it's just so hard for me to wrap my head around it being a bent axle. How in the fk would the axle bend? I haven't jumped or hit anything.
Question: before I tear into it.. could a bad bearing cause the axle to move like that?
Dealership will warranty the axle, but not the bearing. I already have the new bearing, just want a second opinion.. plus I'm trying to avoid rental car charges for a week+.
https://youtu.be/EViVeV90n1A
Rzrman328
The treeline
Looks like an excessive amount of play to be just the bearing. but I also don't think it's a bent axle....hmmm
AustinB
AustinB
Banned
https://youtu.be/nOelF-QsNhc
I was going to swap the axles around and see if the problem follows it.. of course the chrysler axles would be side specific by about 3/4" .
Bearing seemed fine, only thing left would be the axle. Dropping it off monday.
pickupman66
Tennessee
Whole lotta no fun. I was in there last week.
sent from my pixelated Nexus 6p
