Tailgate light bar reverse wire
usocazy
San Antonio, Texas
Hemi 5.7l
Hey folks, thinking on getting one of these light bars for my truck.
It calls for connecting/splicing into the reverse or back up wire.
Where is that located under the rear of the truck?Image1478698625.974196.jpg
Sent from San Antonio, Texas
stimpy433
IOWA
It's the White wire that comes out of your 7 pin plug assembly. If you look at the cover it shows the pin out which should be the center pin of the 7 pin plug.
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
Awesome!!! Thanks for the quick response.
fordtech90
Jonesboro, La 71251
Mine was white wire with red tracer in middle of 7 pin plug.
07MegaCabRam
Chandler, Arizona
6.7L CTD
Yup. White with Red. Hope your light lasts more than 5 months. Never seen one that actually works as designed. haha
You can also grab that same wire behind the tail light.
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
Hope your light lasts more than 5 months. Never seen one that actually works as designed. haha.
Well now, that's definitely something to think about especially since these are stuck to the truck with 3M tape. Not opposed to drilling holes to mount a good set.
Anyone have a light bar that's lasted? Preferably over a year or so?
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
Longevity of the LED light bars were a concerned for me too. I installed a United Pacific #36864 Stop/Turn/Tail LED Glo-bar. It is a DOT approved and intended for use on semi trucks/trailers so it should last a while. All of the internals are epoxy sealed.
fordtech90
Jonesboro, La 71251
Mounted mine here. No problems so far.
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
Longevity of the LED light bars were a concerned for me too. I installed a Union Pacific #36864 Stop/Turn/Tail LED Glo-bar. It is a DOT approved and intended for use on semi trucks/trailers so it should last a while. All of the internals are epoxy sealed.
Any pics you can share?
crash68
Administrator
3.0 EcoDiesel
The red color doesn't show up correctly in the picture, all four brake lights are a similar bright red. These are the brake lights, I didn't wire the running light part of the bar.
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
Union Pacific or United Pacific?
crash68
Administrator
3.0 EcoDiesel
Dumb question, where's the 7 pin plug? My light wiring connector is a 4 plug.
If you don't have a 7 pin trailer plug around/through the bumper, then you probably don't have one
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
So I only have the 4 pin connector.
Anyone have an idea what color the backup wire is and where it's located on these setups?
UPDATE: I'm a moron!!! It pays to look at and fully understand your truck. [emoji5]
1Popeye
