workinguy26
like it says above 2001 ram 1500 want to swap a dana 70 into it. I know about the spring perches and drive shaft but it has disc brakes and I have drum brakes. how does that hook up work?
Should be able to connect brake lines and bleed em like you would the fronts
I have wanted to make this swap. I did not know of the differences or how easy it would be. (potentially depending on mindset)
Others have done the swap before and there's conversion kits out there for the 9.25 that don't include a new master. These masters are a bit stronger than that 79 ramcharger so i wouldn't worry about it. In fact i bet if you cross referenced part numbers they'd probably be the same as the 2500/3500 trucks and if not those would be almost guaranteed to be a direct swap
