No wipers - 99 Ram 2500
Marksman
Texas
1999 Ram 2500 4x4 SLT
V10
Hey everyone. I've finally got my v10 truck where it's roadworthy, and I plan on trying to get it inspected tomorrow. Problem is, I replaced the dead wiper blades to find that the wipers don't function. I'm going to continue on my research, but I thought I'd post here in the meantime to see if anyone else has had the same issue. I checked the fuse and it's fine. I'll look and see if i can find a relay for it. Would it be more likely for the motor or switch to be bad? The truck has right at 200k on it if that's of any use. I don't see the wiper motor in the engine bay so i assume it's under the plastic cowl. Next thing I'll do is check to see if i have power to it.
Thanks!
MagSport
South Carolina
Look at your power lock fuse in the dash. If the CTM goes dead, the wipers will quit functioning.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
had this happen when i didnt use them for a while. Thought i was hosed removed the wiper cowl and each wiper arm and tried them they worked. Put it all back together, and it still worked.
I believe mine was binding somewhere and the jiggling of the wiper arms for removal freed them up. Worth a shot and good Process of Elimination
Marksman
Marksman
Texas
V10
Thanks for the replies guys. The contacts in the switch were dirty and once i moved the switch back and forth about 50 times they came to life. Truck hasn't been on the road for close to 4 years now so i attribute it to that.
Passed inspection without issue. It's officially alive.
Now all I have to deal with are the electrical issues in the doors..
