1985 Dodge Power Ram W150 steering
Brucecmc
Brucecmc
At the parts store
1985 Power Ram W-150
318 V8 5.2L
Not following that Wolfie. Just pound the pin and the plastic piece at same time ? I think it's moot. I'm already pressing forward with mashing down those flanges and devising a way to shore that up some. When I figure something out I'll post it.
crazzywolfie
under the truck
do you got a proper roll pin punch? usually it should just push it right out with a roll pin punch. i did about 2 or 3 a couple months again and all came apart pretty easy but none of my steering boxes were on a vehicle.
Brucecmc
Brucecmc
At the parts store
318 V8 5.2L
I have several sizes of punches. Dunno if they're "proper" or not. But, I think I'll save this for a future effort. Like when I decide this crappy set up needs to be replaced with the borgeson heavy duty telescopic steering shaft #000940 (which I probably should have done instead of this). Guess I was more curious than anything on this effort.
crazzywolfie
under the truck
ya normal flat tip punchs are definitely not the same as a rollpin punch. a roll pin punch has a little bump on the tip the keep the roll pin from bending in when you hammer on it. sometimes having the proper tools makes things so much easier but then again you live and learn. a borgeson steering shaft is the best route to go especially if you plan on keeping the truck.
Sniper X
I did the Borgesson shaft on my 1977 Ramcharger and it rocked. The stock one was sloppy and dangerous.
ajs196
360 5.9L
Bill1982
I'm to lazy to read this entire post but I just did the rebuild kit lastnight with my brother. It is fairly easy and took almost all my play out. If you can grab the shaft and tug on it and it moves a bunch, they say you need a rebuild. RamchargerCentral.Com - Articles - Dodge Steering Coupler Repair - Dodge Ram, Ramcharger, Cummins, Jeep, Durango, Power Wagon, Trailduster, all Mopar Truck & SUV Owners. Dodgeram I know its a different forums page but this guy explains the steps well.
I did mine the cheap way picked up a lower steering shaft with a ujont in it from a late 90s Tahoe shorten my stock shaft carefully ground flats on each side to slide it together and clamped the u joint to the steering box input shaft cost a whole 12$ for the lower shaft off the Tahoe when I did a 3"body lift later the shaft wasn't an issue it's still on and no issues
Sent from my Z832 using Tapatalk
