Dana 60 lube
Relayer
My 2001 Ram 2500 has a Dana 60 rear end that calls for sae 90 gear oil. Problem is i cant seem to find that in local auto parts stores. Does anyone have other recommendation as far as other fluid choices for this rear diff?
BBartow
New Port Richey, Florida
5.9L Magnum
Your rearend takes 80w90, you're having trouble finding that?
1999 White C5 Coupe
Purchase the correct fluid at a RAM dealer.
TruckNoob
Dallas, TX
If you don't want to get it off of Amazon, all Tractor Supply stores carry it. It is a common gear oil used in tractors.
orionlover69
Texas
5.9L V8
:roflsquared:
Just get some 80/90 or 75/140 or whatever gear oil is available. This is not rocket science. If you have a L/S be sure to get with additive or grab a bottle to add.
How much fluid does it take? In quarts. And is grey rtv usable to reseal it?
txram956
