light at the end of the tunnel?
razor1
St.Petersburg Fl
First off thanks to Wild One for the great catch, hope you don't but I running with this sick of my Spohn crap.
Well it looks like finally for us that have lowered trucks and for those that are looking into lowering their truck a solution is on the horizon. As everyone knows after lowering comes more problems. In the past we've resorted to using the Spohn adjustable lower arms. And again problems.
Today I spent about 30 minutes on the phone with Illicit Customs going over the bracket system they have for the rear of the 4th gen Ram trucks that are lowered. The system looks sound and puts everything back in to factory specs. That means your pinion angle is correct your axel is in the center of the truck where it belongs and not pulled forward and shifted to the passenger side. At this point the only drawback I see is that you need to cut the rear end the pads that are welded do the rear end for the bump stops on both sides. Unfortunately that by itself removes your entire rear end of the truck from your factory warranty. As I discussed it further with him he said he would find out in the next few days if he can design it to retain those bump stop pads on the rear end. If all goes well looks like we have a solution finally. At this point the price for the 2 brackets and all hardware is about $500 if you want the heavier duty panhard bar adapter. If you're happy with your panhard bar adapter the price is $400 for both brackets and hardware.
Wild one
14 Sport
Today I spent about 30 minutes on the phone with Illicit Customs going over the bracket system they have for the rear of the 4th gen Ram trucks that are lowered. The system looks sound and puts everything back in to factory specs. That means your pinion angle is correct your axel is in the center of the truck where it belongs and not pulled forward and shifted to the passenger side. At this point the only drawback I see is that you need to cut the rear end the pads that are welded do the rear end for the bump stops on both sides. Unfortunately that by itself removes your entire rear end of the truck from your factory warranty. As I discussed it further with him he said he would find out in the next few days if he can design it to retain those bump stop pads on the rear end. If all goes well looks like we have a solution finally. At this point the price for the 2 brackets and all hardware is about $500 if you want the heavier duty panhard bar adapter. If you're happy with your panhard bar adapter the price is $400 for both brackets and hardware. He also said that if we come up with a group purchase he would find a way to do a better price at that time.
I owe you a thank-you Razor,you posted a lot more info about them then I did. He's supposed to give me a quote later tonight on 3 sets of them sent to Alberta.
moregrip
looks very promising! thanks for the info!
Wild one
14 Sport
I'm interested and hoping he can design bracket to retain bump stop pad.
Actually you only have to do a little trimming on the very front of the bumpstop,just so the bracket sits flush to the housing. Might take all of a couple minutes with a cut-off disc for fitment. Where the factory bumpstop hits the pad is still in place.I can't link to the pic he sent me,but if you're worried about the bumpstop disappearing altogether,you don't have to worry.
Rick
J3FF3RSON
Louisville, Kentucky
2014 Ram R/T
So with THIS, we wouldnt need aftermarket control arms in the rear?
Dude, I'm sold. I was about to shell out 3 times as much for a custom set of control arms!
Dubstep Shep
Houston
2014 R/T
Count me in for a set of the brackets on a group buy. Miiiiight be interested in the panhard relocation, but I'll probably just pick up a belltech.
Any word if they're thinking about making them adjustable for different drop heights?
razor1
razor1
St.Petersburg Fl
he did say he may make the second set with 3 adjustment holes for the lower arm
Wild one
14 Sport
I have the Spohn non-adjustable arms. If it work with them count me in.
The brackets will work with your non-adjustable arms. If you guys have questions hit Ryan up on his page,he's more then willing to answer your questions. He was following the Illicit Customs thread,not sure he's following these other threads though.
I've been twisting Matts arm to carry these,if you guys want him to carry these,put some pressure on him,lol
jag1886
Boise Id Gods country
Demi 5.7 S&B CAI, flowmaster merge collector, Gibson cat back, oil catch can, 87
There is going to have to be a lot more photos and testing of this system installed before I would pop $500 for those. Looks like a very good idea but $500 is a lot of cashola.
My current truck is the only truck I haven't lowered and this looks like a cure for all the problems they have. A lot more info is needed.
RedFlameRam
