crazzywolfie
- Apr 6, 2013
- 16,422
- 3,183
- under the truck
- 81 93
- 5.2
ya you might have to get creative with the fuel filler hose but it might be worth it if your sending unit doesn't work. plus you could probably find a fuel tank cheap if an auto recycler haven't punched a hole in it already. i used the tank out of a 96 grande Cherokee to run my 89 when i first got it before i replaced the pump. it worked perfect other than the fact it pumped quite a bit of gas back into the stock tank. made dropping the tank more of a pain but it is about the only way to do the job on an RC
