light at the end of the tunnel?
12vrunner
Texas dfw
Yes i am ready to lower my truck but more info please.
razor1
razor1
St.Petersburg Fl
There is going to have to be a lot more photos and testing of this system installed before I would pop $500 for those. Looks like a very good idea but $500 is a lot of cashola.
My current truck is the only truck I haven't lowered and this looks like a cure for all the problems they have. A lot more info is needed.
it is $400, $500 if you want the panhard bracket too.
Quicksilver337
South FL
2016 Ram R/T
Are we doing a group buy...I thought I saw somewhere that if we did a group buy it would be cheaper. correct me if I'm wrong
Dubstep Shep
Houston
2014 R/T
I agree. I'm all in for the group buy, but I want to see a bunch of pictures and some third party reviews before I drop that kind of cash.
Wild one
14 Sport
It'll be awhile before I put my set to the test. Jay Greene is getting a set along with the 4 sets we ordered,hopefully Jay will have some results before us Canucks . Our streets and pavement will be to cold to get a decent test for awhile. The way I look at them is they're way cheaper then a chassis shop,and that includes how much they cost into Canada,you guys get them cheap compared to us.
Dubstep Shep
Houston
2014 R/T
I'd be happy to test/buy a set as long as if I didn't like them I could return them.
Wild one
14 Sport
You could try Ryan,he might be in a giving mood,lol. He's already got a set on a buddies truck that they've tested fairly extensively.It might be tough to get a set to test,especially with the idea of returning them,most fab shops don't operate that way:roflsquared:
Worth trying though,all he can say is "no",but if you get a freebee set,i'll sure be ******** at him:roflsquared::roflsquared:
Dubstep Shep
Houston
2014 R/T
Hahahaha, I wouldn't expect them to GIVE them to me. Just sell them to me so I can test them out, give them any feedback and a review and if I really don't like them return them for a refund.
moregrip
is it just me or does the metal on those brackets seem too thin?
Wild one
14 Sport
I'm starting to think you squeak when you walk Shephard,you seem to want everything given to you:roflsquared::roflsquared:.
bgray
Canada
So these fix pinion AND move axle back?
I'll take a set 100%
Sowardcustoms
Burleson TX
5.7 E-Torque
And it allows you to get rid of the top link bar mount that hits the frame way before the axle does.. And in my case moves the upper link farther down so my height sensors dont hit them.
bgray
Canada
Hmmmmm. Looks like the Entire upper Arm mount is cut off and removed from the axle, not just eh bump stop bracket. Im not worried about warranty issues on my 16, but if these dont perform im fucksville at that point.
I'll hold my judgement until members takes the plung and gets results after install and use. They look a bit flimsy to me in the first design, maybe a set of these welded to the axle and a top plate and support welded to the upper mount would help. Box the lower at the bakc to give it rigity I do a lot of towing with my ridetech ram, and that does not look like a ideal setup for side to side weight transfer
