Can I fit 33's?
scubasteve1043
I have an 05 quad cab 2wd with the 2" lift maxtrac springs and the factory 17" chrome clads which have 265/70/17's on them now, they are pretty close to the upper control arms. Can I get a 33" tire and if not I guess the biggest I can go is a 275/70/17 right?
Sent from my LG-H820 using Tapatalk
usaf2006
Augusta, GA
How close is close? My truck is stock with the same wheels and tires, and my tire is about .5 -.75" away from my control arm.
If your distance is about the same, you should be able to fit 33s fine. Just make sure the sidewalls aren't too aggressive and knobby.
S
scubasteve1043
Yeah mine are about .75" away I just wasn't sure how much closer 33's would be, thanks
usaf2006
Augusta, GA
285/70r17s, which are equivalent to 33s, would be skinnier than 33/12.50r17s
S
scubasteve1043
I was wondering if they we're the same or not, i think I will go with those instead
