Transmission Advice
cpc0357
Webster, Fl
5.9l Magnum
I have a 2001 Dodge Ram with the 360 in it. The motor blew two pistons and while pulling the motor I found a crack in the bell housing. I have welded bell housings before but i figured if I am going to be pulling the transmission out I was thinking about doing an automatic to manual swap.
Now I was told the only way to do it is to change the brain out as well. Now besides the obvious things like clutch and pedals is there anything else I need? I have found a parts truck I can pull it off of if I need anything else. If anyone has any tips or tricks or helpful advice it would be greatly appreciated. Thank you.
dapepper9
Iowa/Nebraska Border
5.9L V8
You'll need the correct 360 flywheel and to either ground out they neutral safety switch or swap in a 2001 2500 360/5spd pcm. Don't run a 5.2 pcm with it, it'll run but fuel/spark mapping is different and it won't be correct.
joeyoliver45
