No worries. I asked to make sure you got the info you needed.
1500:
NHTSA Vehicle Safety Recalls
Recall Number
13V528000
Recall Date
11/06/2013
Component
STEERING:LINKAGES:TIE ROD ASSEMBLY
Summary
Chrysler Group LLC (Chrysler) is recalling certain model year 2003-2008 Dodge RAM 2500 4x4 and 3500 4x4, model year 2007-2008 Dodge RAM 3500 4x2 Cab Chassis and model year 2006-2008 Dodge RAM 1500 Mega Cab 4x4 trucks manufactured February 12, 2002, through February 13, 2008. The left tie rod assembly may break.
Consequence
A failure of the tie rod assembly may result in a loss of steering control, increasing the risk of a crash.
What Owners Should Do
Chrysler notified owners and launched its recall campaign in January 2014. Owners may contact Chrysler at 1-800-247-9753. Chrysler's recall campaign number is N62.
Recall Number
10E013000
Recall Date
05/03/2010
Component
STEERING:GEAR BOX:SHAFT PITMAN
Summary
FABTECH IS RECALLING CERTAIN AFTERMARKET REPLACEMENT PITMAN ARMS, P/NOS. FTS93001 AND FT44039, INSTALLED FOR USE ON CERTAIN 2003 THROUGH 2008 DODGE 2500 4WD, 3500 4WD, AND 1500 4WD MEGA CAB VEHICLES. THE PITMAN ARM CAN FRACTURE AND BREAK AWAY FROM THE STEERING BOX CAUSING TOTAL LOSS OF STEERING CONTROL.
Consequence
STEERING LOSS COULD RESULT IN A VEHICLE CRASH POSSIBLY RESULTING IN PROPERTY DAMAGE, INJURY OR DEATH.
FABTECH WILL NOTIFY OWNERS AND AUTHORIZED INSTALLERS WILL INSPECT FOR DEFECTIVE PITMAN ARM AND REPLACE IF NECESSARY FREE OF CHARGE. THE SAFETY RECALL BEGAN ON MAY 24, 2010. OWNERS MAY CONTACT FABTECH AT 1-877-432-2832.
Recall Number
15V313000
Recall Date
05/27/2015
Component
AIR BAGS:FRONTAL
RIVER SIDE INFLATOR MODULE
Summary
Chrysler (FCA US LLC) is recalling certain model year 2005-2009 Dodge Ram 2500, 2004-2008 Dodge Ram 1500 and Durango, 2006-2009 Dodge Ram 3500, 2008-2010 Dodge Ram 4500 and 5500, 2007-2008 Chrysler Aspen, 2005-2010 Chrysler 300, 300C, 300S, and SRT8, 2006-2010 Dodge Charger, 2005-2008 Magnum, 2005-2011 Dodge Dakota, and 2006-2099 Mitsubishi Raider vehicles. The affected vehicles are equipped with a dual-stage driver frontal air bag that may be susceptible to moisture intrusion which, over time, could cause the inflator to rupture.
Consequence
In the event of a crash necessitating deployment of the driver's frontal air bag, the inflator could rupture with metal fragments striking the driver or other occupants resulting in serious injury or death.
Chrysler will notify the affected Chrysler and Dodge owners and Mitsubishi will notify the affected Raider owners. Dealers will replace the driver's frontal air bag inflator, free of charge. The recall began for Chrylser on June 8, 2015. The recall for Mitsubishi started on June 24, 2015. Chrysler and Dodge owners may contact Chrysler customer service at 1-800-853-1403. Mitsubishi owners may call 1-888-648-7820. Chrysler's number for this recall is R25. Note: This recall supersedes recall 14V817 in its entirety. Vehicles that have had their driver side frontal air bag replaced previously need to have their air bag replaced under this recall as well.
Recall Number
14V795000
Recall Date
12/16/2014
Component
ELECTRICAL SYSTEM:IGNITION:SWITCH
Summary
Chrysler Group LLC (Chrysler) is recalling certain model year 2006-2007 Dodge Ram 1500, 2500, 3500, Dakota, and 2006 Mitsubishi Raider vehicles manufactured July 1, 2005, to July 31, 2006 with manual transmissions. The return springs in the clutch ignition interlock switch may break.
Consequence
Broken springs can result in a no-start condition, or cause unintended movement when the ignition is cranked, increasing the risk of a vehicle crash.
Chrysler will notify owners, and dealers will replace the clutch ignition interlock switch, free of charge. The recall began on March 27, 2015. Owners may contact Chrysler customer service at 1-800-853-1403. Chrysler's number for this recall is P80.
Recall Number
10E040000
Recall Date
08/23/2010
Component
WHEELS:CAP/COVER/HUB
Summary
FEDERAL-MOGUL IS RECALLING CERTAIN CARQUEST, NATIONAL, AND PERCISION BRAND WHEEL HUB ASSEMBLIES, P/NOS 515073 AND 515073, SOLD FOR USE AS REPLACEMENT EQUIPMENT ON MODEL YEAR 2002 THROUGH 2008 DODGE RAM 1500 PICKUP TRUCKS. THE INBOARD ROLL FORM USED TO MAINTAIN THE HUB ASSEMBLY CAN FATIGUE RESULTING IN NOISE AND/OR WHEEL SEPARATION ON THE TWO WHEEL DRIVE (2WD) APPLICATIONS. THE RISK OF THESE ISSUES DO NOT OCCUR ON THE FOUR WHEEL DRIVE (4WD) APPLICATIONS, AND INSTALLATION ON THE 4WD APPLICATIONS ARE NOT PART OF THIS RECALL.
Consequence
A VEHICLE CRASH CAN OCCUR IF THE WHEEL SEPARATES FROM THE VEHICLE.
FEDERAL-MOGUL WILL NOTIFY OWNERS OF RECORD AND TECHNICIANS WILL REPLACE THE AFFECTED HUB ASSEMBLIES FREE OF CHARGE. THE SAFETY RECALL BEGAN ON SEPTEMBER 15, 2010. OWNERS MAY CONTACT FEDERAL-MOGUL AT 1-877-489-6659.
Read more at
https://www.cars.com/recalls/dodge-ram_1500-2007/#RMLt4JvrdoCQEH4f.99
2500:
Recall Number
08V641000
Recall Date
12/05/2008
Component
ENGINE AND ENGINE COOLING:ENGINE
IESEL
Summary
CHRYSLER IS RECALLING 108,429 MY 2007-2008 DODGE RAM 2500 AND 3500 PICKUP TRUCKS EQUIPPED WITH 6.7L DIESEL ENGINES. A SILENCER PAD CAN SAG AND CONTACT THE EXHAUST GAS RECIRCULATION (EGR) COOLER.
Consequence
THIS COULD RESULT IN AN ENGINE COMPARTMENT FIRE.
DEALERS WILL ADD A BRACKET TO SUPPORT THE ENGINE COMPARTMENT SILENCER PAD ADJACENT TO THE EGR COOLER. THE RECALL IS EXPECTED TO BEGIN DURING DECEMBER 2008. OWNERS MAY CONTACT CHRYSLER AT 1-800-853-1403.
Recall Number
06V341000
Recall Date
09/07/2006
Component
POWER TRAIN:AUTOMATIC TRANSMISSION
Summary
ON CERTAIN PASSENGER AND SPORT UTILITY VEHICLES AND PICKUP TRUCKS EQUIPPED WITH AUTOMATIC TRANSMISSIONS, THE SOFTWARE PROGRAMMED INTO THE POWERTRAIN CONTROL MODULE CAN CAUSE A MOMENTARY LOCK UP OF THE DRIVE WHEELS IF THE VEHICLE IS TRAVELING OVER 40 MPH AND THE OPERATOR SHIFTS FROM DRIVE TO NEUTRAL AND BACK TO DRIVE.
Consequence
IF THE DRIVE WHEELS LOCKED UP, LOSS OF VEHICLE CONTROL COULD OCCUR INCREASING THE RISK OF A CRASH.
DEALERS WILL REPROGRAM THE POWERTRAIN CONTROL MODULE FREE OF CHARGE. THE RECALL BEGAN ON OCTOBER 2, 2006. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Recall Number
07E009000
Recall Date
02/01/2007
Component
SUSPENSION
Summary
CERTAIN LKI ENTERPRISES, INC., BRAND NAME SUPERLIFT SUSPENSION, PITMAN ARMS SOLD AS REPLACEMENT EQUIPMENT FOR 2003-2007 DODGE RAM 2500 AND 3500 4X4 LIGHT TRUCKS. DUE TO INADEQUATE HEAT TREATMENT DURING PRODUCTION, THE AFFECTED PITMAN ARMS MAY DEVELOP CRACKS IN THE UPPER SPLINED ATTACHMENT ATTACHMENT TO THE STEERING OUTPUT SHAFT. MOVEMENT BETWEEN THE PITMAN ARM AND THE OUTPUT SHAFT MAY DEFORM SPLINES, RESULTING IN PREMATURE WEAR AND FATIGUE FAILURE OF THE AFFECTED PITMAN ARM.
Consequence
PITMAN ARM WEAR OR FAILURE MAY LEAD TO LOSS OF VEHICLE CONTROL, POSSIBLY RESULTING IN A VEHICLE CRASH.
LKI WILL NOTIFY OWNERS AND REPLACE THE PITMAN ARM, IF NECESSARY. THE RECALL BEGAN ON MARCH 12, 2007. OWNERS MAY CONTACT LKI AT 1-800-551-4955.
Recall Number
07E104000
Recall Date
12/11/2007
Component
VISIBILITY:GLASS, SIDE/REAR
Summary
CERTAIN CURVED TEMPERED REPLACEMENT GLASS MANUFACTURED BY HANGZHOU SAFETY GLASS LTD AND SUPPLIED TO SAFELITE BY AUTO TEMP INC., IDENTIFIED AS DOT-430, AND SOLD FOR USE ON CERTAIN DOMESTIC AND FOREIGN VEHICLES MAY NOT BREAK INTO SMALL PIECES AS EXPECTED OF TEMPERED GLASS AND FAILS TO CONFORM TO FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 205, "GLAZING MATERIALS."
Consequence
IN THE EVENT OF A VEHICLE CRASH, THE OCCUPANT(S) MAY BE SERIOUSLY INJURED BY SHATTERED GLASS.
SAFELITE WILL NOTIFY ITS RETAIL CUSTOMERS AND REPLACE THE GLASS FREE OF CHARGE. RETAIL CUSTOMERS CAN CONTACT SAFELITE TOLL FREE AT 1-888-843-2906. SAFELITE WILL NOTIFY ITS WHOLESALE CUSTOMERS AND REIMBURSE WHOLESALE CUSTOMERS FOR CURRENT INVENTORY AND AT A SPECIFIED RATE FOR REPLACING THEIR CUSTOMER'S GLASS. WHOLESALE CUSTOMERS CAN CONTACT SAFELITE'S WHOLESALE DIVISION, SERVICE AUTOGLASS TOLL FREE AT 1-888-246-6298. THE RECALL BEGAN ON JANUARY 15, 2008.
Recall Number
14V795000
Recall Date
12/16/2014
Component
Summary
Consequence
Read more at
https://www.cars.com/recalls/dodge-ram_2500-2007/#tkljs4qfHt1Hr4Zf.99
2007 Dodge Ram 2500 Technical Service Bulletins
2007 Dodge Ram 2500 TSBs (Technical Service Bulletins) | DodgeProblems.com
2007 Dodge Ram 1500 Technical Service Bulletins
2007 Dodge Ram 1500 TSBs (Technical Service Bulletins) | DodgeProblems.com
