lighting issues. headlights. interior lights not working right
farmer andrew
5.7l
hey so i have a 2013 dodge ram 1500 laramaie 5.7l. about a month ago my low beams and fog lights got very dull, i have installed led bulbs with all the appropriate wiring and there still dull. also have had the roof lights between driver and passanger flicker when door is open and the gauge back lights flicker aswell. any help is appreciated truck has 100399km on it... never been abused at all
bhonshell37
Washington
Is the plastic lense of the fog lights cloudy and dull. You may have a loose ground or some leads to the lights are loose or corroded.
Sent from my SM-T550 using Tapatalk
F
farmer andrew
5.7l
lens are clear. and not sure where to even start looking... im not frmilular with dodge at all. could it be the tipm is bad?
bhonshell37
Washington
I suggest you find a Chilton manual for your truck. I have one for my 2004 with the hemi. Easy to follow and good detail
bhonshell37
Washington
Pull the covers off of the lights you can and clean the connections and check for loose wires
F
farmer andrew
5.7l
i put the leds in the other day and they werent lose but i will check that again. is there any other reason they could be dulling
bhonshell37
Washington
The only issue that comes to mind is you may have used to heavy of a gage wire and the current is having an issue not being dispersed before reaching the bulb
bhonshell37
Washington
Something else to check is the bulbs. Even though they are new, the bulbs could be bad which could be the cause for the dimness.
txram956
