What good battery to power my hemi nd system
1BadRam08
What good battery to power my hemi nd system ,I have a system with 2 8in 900rms watts nd have an amp of 1500 watts but instead of getting a capacitor I think I should get a battery or a better alternator.
Sent from my SM-G935V using Tapatalk
Eestee70
Chicago
I would recommend going with a secondary battery, one specifically to run your audio equipment. this would also prevent your headlights from dimming when your bass hits hard.
1BadRam08
I think that's what ima do but I wanna have the battery under the hood but I couldn't find room for it
Eestee70
Chicago
Look into the XS power or stinger secondary batteries their about half the size of the regular battery and can be mounted in the cab and in any position.
1BadRam08
Ight thanks I'll look into that but would I need a power cable running to the original battery to give it power to the 2nd one or no
Eestee70
Chicago
Yep you would need to run a power wire and ground it to the body wherever you mount it. also make sure you put in a fusable link between your secondary battery and your amp. Sounds like a lot to do but if you plan your work it will be pretty simple.
