weird problem NEED HELP
Scottlanham
Magnum 5.9
First of all, my dodge won't shift down into gear 1 at all
Second of all after going out of 4wd my truck will not go into park
Does anyone know what this could be?
02 Dodge Ram 1500 4x4 SLT
Ram Lover
Maine
5.9L 360
Not sure about the 4x4 unless it's related to problem number 1, does first work if you put the shifter in first? It could be your shift solenoid, mine did that after I changed the filter and fluid it sucked up crap and had to do it all over to change the solenoid, but check the simple things first, fluid full, does it smell burnt? Change fluid and filter, then if possible a good transmission guy should be able to tell you what's up, and maybe scan it, the guy I use scanned mine and in 2 sec told me the solenoid thought the truck was going 10 mph in park.
Sent from my SM-S320VL using Tapatalk
