Zone install pictures with questions
EvoNiner1986
Had my Zone lift installed on my EcoDiesel and took pictures on something I wanted to make sure was done correctly. Input appreciated
You can see how the 'mount' or whatever it's called on driver side looks like it was cut, and the passenger side wasn't (2 full holes on that one). Just want to make sure this was done correctly, thanks!!
Solid State
2011 Bighorn
The crossmember needs to be cut on the drivers side to clear the front difrerential.
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Looks good to me. Like Solid State said, you do need to cut the stock crossmember in order to allow the drop of the differential.
Adam
6.7CumminsDrvr
The Dude abides………
Georgia
Looks good to me. I have a different brand but mine was only trimmed on one side aswell.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
As the others have stated, yes that's done correctly. Any proper lift kit that comes with a front differential drop brackets requires that OEM crossmember mount to be cut off to provide the clearance for the front diff to drop down.
57buick
Salem, OR
6.7L diesel
What model truck and which lift? I installed a Zone 6" lift on my 2015 2500 diesel and I didn't do any cutting?
brandonjansen
1500's require the cutting. 2500/3500's have a completely different front suspension and therefore different requirements.
