Help with bed led strips
Malibuz0r
So I'm not very good with electrics, after a bunch of googling I've wired the bed lights my self.
Everything seems to work great WHEN the truck is off.
The way I wired the bed lights is I tapped to the cargo lights wire (white w/ tan stripe), so they turn on when I unlock the truck or pressing the cargo light button inside. That works fine.
Now, the problem is that whenever the truck is on, and I press the cargo light button, both the cargo light and the bed led strips turn on for a second then off. The cargo light indicator on the cluster remains on though..
Here's a ********ly made diagram of how I wired them..
Any idea what I'm doing wrong?
Thanks
Edit: Here's what I'm using for the LED strips
Brew99
Victoria, Canada
I don't know exactly what might be your issue, but I suggest troubleshooting first buy removing the 5a fuse, and trying to see if the cargo light works as normal. Leave all else hooked up.
I wonder if the load is too much for the cargo light circuit, and it shuts it down?
Sorry I can't be of more help
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
It's possibly because the cargo light is monitored for burn out like practically all the light bulbs are and you have added the additional ground path. I've read about people having similar issues wiring aux LEDs in as back-up lights in a similar fashion. Also too much/not enough current can also cause issues.
Add a switch and power the LED strips off the battery(move your fuse close to the battery) or the 12 V wire going to the 7 pin trailer plug.
sbarron
Wasilla, Alaska
As Brew stated, pull the fuse and check your cargo light. If it works as normal, the extra load from the bed lights is causing the CANBUS system to shut he circuit down. In that case use the cargo light power as a trigger signal for a relay. Done and done.
Reactions: 9th
Ram Man
FL
2013 Sport
I just wired in some led lights to the 7 pin this weekend but didn't have time to hook up a fuse inline... How important is this step?
I keep outsmarting my common sense on this question...
SilverStreak88
Houston, Texas
5.7 Eco Gasser
LED's take such little power to run you should be OK, but I would for sure throw a 10A fuse in there.
crash68
Administrator
3.0 EcoDiesel
If you use a smaller fuse for the LEDs, if something goes wrong, you won't lose the one under the hood for the plug itself. The size switch I used would probably melt if 20 amps went through it
2015HD
Maine
^This
The burnout monitoring caused me all sorts of headaches trying to install a backup camera by tapping into reverse lights. Finally got frustrated and had OEM backup camera installed.
M
Malibuz0r
Thanks guys. The relay was indeed what was needed. I had to wait almost a week from when I made my post until today to get installed. Car rear ended my baby..
