Need help with 5100s
Hi all new to the forum. I am about to inherit my dad's 2010 trx 4 and it needs shocks all the way around. I'm wanting to do 5100s all the way around to level it in the front but I haven't found anywhere that says if the rear 5100s need at least one inch of lift to fit correctly. So the question is will the rear 5100s fit without a rear lift?
Ricks Ram
Yes they will fit. They are capable of handling up to1" of lift but are fine for stock height as well.
Wrigley17
What Rick said. I have front and rears on, stock height in back
K
Awesome, what setting do I need to set the front at to get a perfect level or slight squat and what would be the largest tire size I could clear?
Wrigley17
Most will say 2.1. You're truck is already set st .7 from what I've read here.
K
What would be the biggest tire I could fit after the level? I want to full the wheel well up
Synolimit
Ohio
I'm 2.1 and rear 0.75. I just did 295/65/20 nitto G2 on the OEM wheels with no spacers. Zero issues! Mounted height is 3" over OEM.
Alaskanpeeps
Try the search function there are hundreds of 5100 threads. Google works 2!!!!!!!!!!
Eddo
