Suspension popping/clunking
zeddy
Burbank, Ca
Suspension popping/clunking warranty denied
So, i took my truck in for popping from the suspension. I looked online and alot people had that issue answer there's is a tsb out for the body mount.
The dealer called and said that they have tightened everything and nothing was loose. They said the popping noise is still there. They're saying that my 2.5 leveling is the cause of it. Before they can go further with the body mounts, I have to remove the leveling kit.
Really?
PCT
2019 2500 6.4
Northern California
What kind of leveling do you have?
Sent from my SAMSUNG-SM-T817A using Tapatalk
SETEX 6.4
Port Neches, TX
Front cab body mounts. My 2014 2500 mega had a clunk under the passenger floor board. New version body mounts fixed the broblem.
Sent from my SAMSUNG-SM-G891A using Tapatalk
zeddy
zeddy
Burbank, Ca
Yeah, they said I have to bring it back to stock first.
R.L.K.
Bristol , Tn.
This is a standard response from the dealer .
Is the 2.5" Rough Country level a front spacer install?
zeddy
zeddy
Burbank, Ca
Yes just a 2.5 spacer. They said the geometry is off, that'd why it's popping.
PCT
2019 2500 6.4
Northern California
Sorry for late responce, I had RC spacers at 2.5, never had popping issues, I would say your UCA are under stress..
zeddy
zeddy
Burbank, Ca
Solid front ends have uca???
Sent from my SM-G935V using Tapatalk
PCT
2019 2500 6.4
Northern California
Sorry didn't realize your had a 2500, on tapatalk... 2.5 really shouldn't throw geometry off... my guess, was installed incorrectly?
zeddy
zeddy
Burbank, Ca
I have it installed for just over a year now. Never had issues. Started popping about two weeks now. Especially when it's cold.
PCT
2019 2500 6.4
Northern California
I'm assuming the spacer fits ontop of the coil tower/assembly. Is there a chance that the assembly is slightly compromised and the cold exasperated it? Cause 2.5 inches isn't a lot of lift, yeah it's about the max you want to go before you deal with geometry, unless the new HD trucks are different
zeddy
zeddy
Burbank, Ca
Coils are straight, nothing loose. the spacer actually bolts onto the spring bucket (if that's what it's called). Dealer said they checked and tightened everything. they said i altered the geometry of the truck thus causing the popping/clunk (they won't fix a known/common problem with the HD's because i have a leveling kit, and can't fix other issues). I really dont know anymore, as much i love my truck, i think i'm done with this truck and ram....people warned me about dodge, horrible customer service, don't take care of their product. Took the benefit of the doubt. should of stuck with nissan. Nissan always stuck behind their product and always takes care of their customer.
just a little frustrated....
BIGWHITE16
TEXAS
2016 Ram 2500 Tradesman
6.4L HEMI
I have a 2.5" pro comp coil spacer. No popping. No clunking.
zeddy
zeddy
Burbank, Ca
I have mine for over year and never had a single noise come from the suspension. There's a guy who posted a video of the body mount popping. Sounds the exact same.... Started a few weeks ago. The symptoms are right on the money when it comes to the body mount TSB, to the "T".
PCT
2019 2500 6.4
Northern California
Sorry haven't been much help...
Sorry for ignorance, TSB as in dealer fix, or something else?
zeddy
zeddy
Burbank, Ca
Can't figure it out. I even tightened the body mounts and same thing. Every other bolt/nut nice and tight.
Ratket
Arizona-
Doesn't matter what brand it is.. unless u are buddy buddy with the dealership and they installed the aftermarket parts - This is a prime example of what happens. Unfortunately you will most likely have to pull the spacers and get the truck to mimic the noise with one of their techs in it. Other than that they are just gonna keep blaming the after market parts. And again let me stress that issue right there is not just a " Dodge " issue- My local ford dealership is the same way.. I suggest you start making friends with their service writer- Or maybe reach out to a after market shop for help- I like rough country - But they won't be able to help you at all- Maybe look to a more " Dosge aftermarket shop- Or company that deals with these trucks-
Dodge off road . Com-
Cjc off road . Com-
Try describing your issue and see what they have heard/ Noticed?
I know my truck pops on the driver side when I over extend the suspension-
I am not sure how your springs could be perfectly straight because in order to get that 2" or 2.5" you compressed those springers by adding a spacer-
Maybe toss up some pics for us? -
Maybe try a different dealer?
If the dealer is the same one you bought the truck from - Start hunting you will shop else where..
zeddy
zeddy
Burbank, Ca
Yeah, the coils are bowed alittle.
I've been looking around and some torquing the body mounts down. I torqued them down about another 1/2 a turn. Today's the second day and haven't heard anything yet (knock on wood). I knew it had to do with the body mounts.
mmcquinn
