What rim size?
Idaho Falls, ID
I am new to trucks in general and I am looking at replacing my stock 20" for some new ones.
My question is, what size rim should I get? Will it have a big affect on how much tires cost?
My truck came with fairly new Duratracs on it so I am not sure if I should just stay with 20"s and continue using the Duratracs or move to a different size.
MADDOG
Out Exploring Arizona
You might check some tire pricing, i.e., is an 18" BFG KO2 more or less expensive than a 20" BFG KO2?
I went from 20" stock to 18" aftermarket because 1) I wanted a bit wider wheel, 2) I wanted a different offset, and, 3) I wanted more sidewall and not have to lift the truck 4".
djmaincheese
5.7 Hemi V8
Stay in the 20" range, If you plan on lifting the truck then you can go with a 22" Wheels and 35" Tires but you will be looking at about $3400
I just upgraded to 20X9 Fuel Vector's with 20mm Offset
Tires are 305/55/20
$2200 for the Wheels/Tires/TPMS installed
