What did you do to your Gen3 today?
ST-8
There cut just a tad. All I switched was spindals. I think it has something to do with all that extra weight of the mcgaughys, because my truck seemed to have a lot of bump steer an just took bumps an potholes an **** rough. My truck is a DD if it wasn't I would of left it the way it was if not lower. But Im in it everyday an it just got old to deal with after so long that low, if it was a weekend warrior I wouldn't have any complaints at 5/7.5
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
I gotcha, I ran spindles as my primary drop before I added 3" drop springs, I have heard of others getting bump steer from it but I never noticed it on mine when I was using it as a daily, but I can fully understand your situation, if I had to daily mine id probably go back to a 2/4 like I used to have, to not have issues getting into parking lots would be an amazing feeling hahaha
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
fired her up fer werk.....ran good 'cept for the scraping feel thru the steering wheel
ST-8
Somebitch is getting some attention this week!
Lil_Ram
Power tech 3.7L
Ordered up a compstar remote start kit from bestbuy with geek squad install. Gonna go see Friday if they'll install my keyless entry as well.
Getting a new power steering pump ordered and installed this weekend as well mines really whinnying in this cold and the tires have killed my factory one.
Got to work tonight on preparing my lower air dam and the piece that goes on the middle of the bumper to be color matched with the truck. It's all scuffed and stuff just need some primer and paint to call it a day. Decided I'll give it a high gloss silver to continue we're I stopped but I'm going to give a black flake as well to really make it shine.
lanceohemi06
Northwest Florida
Installed and adjusted my new headlights; personally changed the oil and rotated my tires for first time in years. Man it feels good getting back under the jack stands.
aheeejd
4.7 V8
Going to change my fluid today, also my tackle pinion seal, did fluid on front differential when I had engine out. Was quite low on fluid, hence pinion seal. Change out fluid in transfer case to I still need to do.
Sent from my LG-ls990 using Tapatalk
Demon-HeMi
Houston
what headlights did you get?
usaf2006
Augusta, GA
Put 89 octane in the other day, but with the rash of cold weather, my gas mileage has been crap with running my truck in the morning.
Well be doing my rear diff fluid this weekend too lol
aheeejd
4.7 V8
Just did mine. My cover was horrible, so I wire wheeled it, little primer, & some black paint. Do either of you guys or anyone else for that matter know what rear end I have. The tab says 3.9, but when I look in book for the 03 it says 9 1/4, 10 1/2 AA or 11 1/2 AA.
I'm guessing its the 9 1/4?
bulrid8
The 3.9 would mean 3.92 gears.
Sent from my VS985 4G using Tapatalk
Bullitt5339
St Pauls, NC
I got a new set of headlights for the truck today. They're a lot darker than the pictures online showed, but I don't drive the truck very often and rarely at night, so they'll be OK. It may motivate me to wire up my fog lights. I will go get some silicone tomorrow, get them sealed up really well and get them installed.
Bullitt5339
St Pauls, NC
Got them installed today. Now I just need to order the rest of the stuff to finish up the front bumper so I can get it painted.
Lil_Ram
Power tech 3.7L
I had good luck with bluer light when I had a set of those.
Bullitt5339
St Pauls, NC
I rarely drive at night, so I'm going to actually wire the foglights up sometime this week and put LEDs in all of them to get it as bright as possible. I'm keeping the stockers in case they give me a hard time for inspections.
rocket
connecticut
was 2006
was a HEMI 5.7
my led fogs were plug an play........seems ok, not as bright as the hid fogs...but less headaches.
lasse452
