Blower problem
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
2006 ram 1500 5.7 only blows air on highest setting could the switch be going out or something else causing the problem?
Sent from my SM-G900R4 using Tapatalk
82Crew
North of St. Louis
318 Magnum, 6.7 Cummins
More than likely it is the blower resistor. High speed bypasses the resistor.
wiram
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
Thank you that's what my friend said just wanted a few opinions before I do anything
wiram
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
So I replaced it tonight the old one was cracked. Still have the same issue any other ideas?
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Had a car do it once and it was the actual control unit.
RonJon '06
Southern Minnesota
Have you checked the recirc door? The hinges tend to break and the door can block the passage cutting off the airflow. This happened on my '06 a few years ago.
wiram
wiram
Sparta, wisconsin
hemi 5.7, 5.2 318
It blows like normal only on the highest setting.
Langer5192
Might help, might not. I was having issues with the control of my blower motor. I found a wiring harness under steering column and when i shook/moved it, the blower motor would start propperly working, i heard these get loose corroded all the time
