Carb issues?
clayton.edberg
31i
My truck is a 318 1 barrel carb when i put it in gear and step on the gas it will die unless i barley touch it if im in park i can rev it up all day with no issues it only when i put it in gear how can i fix that 89184629692820d4d3d6c9046a49b632.jpg
Sent from my LGLS992 using Tapatalk
Dead Reckon
318 LA
See if you can get us a video of what it's doing, hard to say by the description, vacuum leak maybe?
clayton.edberg
clayton.edberg
31i
Ok will do when i get a chance
clayton.edberg
clayton.edberg
31i
Im trying to upload the vid but the app is not letting me
DustyDog99
US
1985 D250, 1986 W150
1985:318-2bbl 1986:318-4bbl
Do you have a tach or access to one? If so the make sure you idle rpm is set correctly. Is it worse cold or does it not make a difference? Check your timing too. Should be about 12-14degrees if your running 85 octane, 16 if you are running mid grade or higher.
Sent from my SM-S727VL using Tapatalk
1Popeye
