ewbloom
- Aug 30, 2013
- 23
- 0
- Sourthern Illinois
- 1988 D100
- 3.9L V6
I trying to find the pick and orange wire fusible link for my blower, I found a bad patch with a broken wire.
The battery side has five wires coming out of one black wire. Four of the wires are 12ga (I think) with one being much heavier. The broken wire had a bad patch link the feed to a pair of wires (one black, one pink) both 12ga or maybe 10ga.
Both ends with multiple wires are clearly molded pieces and meant to merge the wires.
So what might this fusible link be? And what size do I need to get to replace it?
I have enough wire coming from the 5 wire end to make a connection. The other end where the black and pink are connected will need to be cut becuase the break was right at the molded rubber / plastic.
