2017 egr delete
jpsfj60
2016 2500 HD
Where do I get a EGR DELETE KIT for a 17 6.7? I was told the 2016 6.7's
are different than the 2017 6.7's. So I can use a EGR delete that the 2016
6.7's use?
BWC
Northern CO
Cummins
Im curious what the difference would be. Ill look into it
BWC
Northern CO
Cummins
As far as I know they are the same. What were you told was different?
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
As far as I know there's nothing different for the EGR system on any 2013+ trucks. I would check out Sinister Diesel for an EGR and cooler delete kit.
Just to state the obvious, you will also need a delete capable tuner installed before removing the EGR.
