M² Mods Intro & Project List
Mpgrimm2
SC
2022 Ram 1500 (5th Gen)
5.7L
Hi everyone!
Deereguy and I decided to start a little side project to help out our fellow members with various wiring harnesses and mods for some of the smaller projects and threads around the 4th Gen section for our 2013-2018 trucks.
Each of us will be focusing on specific projects as listed in the next 4-5 posts.
We are calling our joint venture: M² Mods
For now, contact us via Private Message (pm)/conversation so we can give you our contact info with all the details (click our user profile picture). Thank you in advance.
M² Mods
Mpgrimm2 (Mike G.) & Deereguy (Mike D.)
PLEASE NOTE:
All harnesses are made one at a time (some take several hrs ea) in order of request. We will not collect anything until your harness is ready to ship (PayPal invoice with their std. buyer protection).
We will be doing this in addition to our regular jobs so please be patient, and we will do our very best to keep you updated with timelines. Harnesses are built using Chrysler spec'd automotive wire (not cheap eBay UL hookup wire like others use). Most people find the quality worth the wait.
M2Mods rock and I said it before but I don't mind saying it again.........
"You can pay more but you can't buy better than a M2Mods product"
------------ ORDER UPDATES/ETAs ----------
6/1/20
Side note: ** DeereGuy got promoted at his day job and will only be offering the Obd Bypass Harness and some Cargo Cam harnesses while he can still get the parts.
See DeereGuy Status.
Disclaimer:
Performing these or any modifications to your truck could void your manufacturer's warranty and/or cause issues with the function of the truck. By purchasing and/or installing any of these custom items (harness, bypass plugs, etc) you agree to absolv M² Mods, Mpgrimm2, Deereguy, and all associates of any and all damages that may occur as a result of installing said item. If you do not agree to this provision, please do not purchase and/or promptly return the item(s) for a full refund (less 15% shipping/restock fee). Additionally, we reserve the right to refuse/cancel an order at our discretion.
Mpgrimm2
Mpgrimm2
SC
5.7L
Mpgrimm2's Current Projects: (Shipped prices are in USA/Lower 48 only)
1) DIY: 2013-2017 RA3/RA4 8.4" Radio Upgrade/HVAC Conversion.
Related - How To: Install a 2018 4C (UAQ/UAS) Radio in 2013 - 2017 RAM.
Related - How to Add AutoTemp Control (ATC) to an MTC truck
Related - Adding dual zone atc to a tradesman
NEW 8/26/20 - 4 & 7spd Universal Conversion harness w/ATC Pt1 (v4): $175
... www.M2Mods4Ram.com
( same price as our original harness with ATC Pt1 built in )
..... 4spd/7spd support in same harness
..... Single Zone ATC part 1 built in (ie for Cabin Temp Sensor)
..... Just add our plug n play v4 fan harness for 2500/3500 4 speed fan trucks
..... Just add our ATC part 2 harness if needed (for 14+ 1500's/classic)
..... Support for Dual Zone ATC ... For those wanting to add extra blend door. See Here
..... Will have to custom build rest of Pass. blend door wiring into add-on harness ($30)
See R.L.K.'s Install pictures here.
- See DeereGuy's: How to Add AutoTemp Control (ATC) to an MTC truck
- ATC Temp Sensor/Humidity Sensor Universal Add-on Harness Set v2: ($220)
2 part harness ... 13-18 RAM ATC Conversion Instructions v2 10-28-18.pdf
... Part 1: $140 (Built into our Universal 8.4 Conv. harness!)
... ATC Sensor harness that plugs into the HVAC module same as before for all 13-18 trucks
... Part 2: $80 (+$30 w/BuCam Mirror Reroute built in)
Humidity Sensor harness that plugs into the mirror header harness behind the pass. air vent & connects to the first harness . Only req'd for 2014-2018 (&19c) 1500's (not req'd for 13+ 2500/3500s)
** ATC Dual Zone add-on Option: $250 (with above)
... Can now add in additional plug n play wiring to support extra blend door for true Dual Zone ATC for those willing to remove/replace their plenum box, etc. See StecoD and Ricks Ram thread: See Here
- 4 Speed Fan Motor Power/Resistor Harness: $65
UPDATE: Our v4 Harness no longer requires removal and repining of the i32A connector. Much Easier!
(made in house for conversion vs stripping down/prepping the more expensive OEM 68048906AA harness, ie $120).
- Fakra D Cell Bypass: $35 with any other item
... www.M2Mods4Ram.com ... $40 on its own
- ** Single Zone MTC to Sgl Zone ATC Bezel Conversion Service: (Labor & Rtn Ship.)
This is a pre-modified board installed/exchanged in customer's MTC Bezel with Auto/Off Center knob. Contact me for current pricing and complete, modified bezel options.
No spare parts returned. Based on part availability.
Note: $140 if you provide both a working Dual Zone & Single Zone bezel to be combined/modified. Takes about 6 hrs to modify the board.
See DeereGuy's: How to Add AutoTemp Control (ATC) to an MTC truck POST 8
Mpgrimm2
Mpgrimm2
SC
5.7L
Additional Harnesses:
- 2013-18/Classic Foglight Extension harness: $80 shipped/USA
This will allow you to buy the official Mopar Foglight "Jumper" harness that goes into the bumper and plug in the "Extension" harness that will install in the factory connector under the PDC. Combined with the Mopar foglight switch and additional hardware, it's as close to the factory wiring as you can get.
DIY: Add 2013-2017 OEM Foglight Wiring.
- NEW 5th Gen 2019+ 2500 Foglight BCM Extension/bumper harness set: $165 shipped/USA (+$20 for 1500's)
*** Limited Supply/Availability ***
* If you plan to use factory LED fog assy's, let me know and I will repin the Mopar bumper harness for you *
REF...5th Gen 2019+ Foglight Add-on harness.
- 2013-16 Backup Camera Chassis & Cab Harness: $225 shipped/USA
(140" WB trucks. Longer trucks are slightly more).
Matches missing factory segments for specific 2013-2016 trucks. Just like Jeepguy would have done it! RiP!)
Ref: Installing OEM backup cam - Post 10 and specifically Post 14 ... pictures in Ramped's Salvage Truck thread
- Chassis Harness: $165 Shipped/USA (140" WB trucks) edb5da3624b1c0cf63b0d8d44b02f953.jpg
- Cab Harness: $60 Shipped/USA 9f6cef4898d029e17abe2e75113ce3f3.jpg
- - Backup Camera Mirror Re-Route harness v2: $70 Shipped/USA
... Also available with Mic Reroute (add $30) to allow 17-19 Trucks to use earlier mirror w/mics. (See new version below)
Plug n Play at connector behind the pass air vent (mirror header), still need to install 3 pins into the radio connector.
NEW - 2017-18/Classic Overhead Mic Add-on Harness: $70 Shipped/USA
... Also available with Compass/HomeLink Module Wiring Add-On (add $30)
NEW - 2013-18/Classic Overhead Console Lighting Harness: $70 Shipped/USA
... Req's manual splicing at specific locations in truck based on year/model.
NEW - 2013-18/Classic Hood Latch Front End/PDC connector to BCM extension harness : $50 Shipped/USA
- UAx USB Hub Adapter Harness: $45 with any other item
... www.M2Mods4Ram.com Site launch ... $50 on it's own UAx Hub Harness Cropped.jpg
Mpgrimm2
Mpgrimm2
SC
5.7L
And I'm taking this over from DeereGuy...
How To Add Heated/Ventilated seats and Heated Wheel to Express/Tradesman.
- PDC to Driver Seat (Power Adj. Seat ONLY): $75
Heated Seat & Wheel harnesses ($350 & up)
- Standard Heated/cooled seat & wheel power harness set: available
Options:
- Memory Seat/Mirror wiring add-on: available
- Inverter PDC power prep add-on: *
- Inverter to dash outlet harness *
- Rear Heated Seat Power prep add-on *
- Rear Heated seat harness
(req's console swap with rear seat switch panel ... ie Crew Cab, Auto Trans only) *
NOTES:
* Additional wiring required to complete install of these items; purchased separately.
** Heated/cooled seat & memory requires BCM config changes/self-programming via AlfaOBD/OBDLink MX BT adapter or OBDgenie **
DeereGuy
Pittsburgh, PA
DeereGuy's Current Projects
2018 RAM Security Module Bypass - $55
Purchase Here
Enables 3rd party tools to read and clear codes and make configuration changes that are blocked by the security module that was added to the 2018 RAMs.
RAM 4C (UAS/UAQ) Media Hub Adapter Harness - $40
Purchase Here
R.L.K.
Bristol , Tn.
Awesome !
Glad to see you guys up and running and good luck to you both !
quietpeen
2021 TRX
Hellcat
Awesome guys. If there are any threads that are mostly yours that you want moved here let me know and I can do that for you
Rickysfloor
Hey brother!!
I am working in my RA3 convertion and i need the 7 speed harness.
R.L.K.
Bristol , Tn.
Hey brother!!
If you haven't done so already , just send Mpgrimm2 a private message and include your email.
And welcome to the forum Sir from NE Tennessee , I see this is your first post !
Mpgrimm2
Mpgrimm2
SC
5.7L
Hey brother!!
Hi Ricky,
Tell Marcelo I said hello. My email decided to crap itself and wont send out any messages (of all the days!). I'm trying to get it squared away before I head to work but will get back to you shortly. I PM'd Avgas.
Mpgrimm2
Mpgrimm2
SC
5.7L
I've had people looking for a microphone mirror harness to add hands free when doing the 8.4 upgrade.
Fyi, I have that info added to the Conversion harness thread under Optional Parts if they need it.
Sent from my non-flammable Galaxy S7!
Ram_Fish1
Indiana
2013 BigHorn CC 4x4
5.7L
This is bad ass guys, I will definately be a customer in near future for ra4 4speed conversion harness, and am very hopeful to see a backup cam harness similar to jeepguys previous kit
69mach1
Cummings 6.7
Great news guys :happy107: I'd like at least a short fog light harness with the terminals and seals for the connector under the PDC :naughty:
MaizeNBlue
Suggestions for the future. ... Power Fold Mirror Harness, Aux Reverse Lights Harness, Rear Power Slider Window Harness.... just spit balling
Mpgrimm2
Mpgrimm2
SC
5.7L
If you really want one, I can make it (@$130). I have made two so far for members. You just need to check all four connectors in your truck to make sure it will work for you and still buy a few items for inside the tailgate. It may not make financial sense vs buying the full Mopar kit unless you want the same wiring as a factory truck.
It's coming soon. I will be ordering some parts to do it within the next week to make one for Bullitt5244's truck (need one on mine too).
It will have a ground/ring terminal next to the PDC and 2 pins from the PDC pins (23 & 24 I think) down to 2 factory fog connectors. One single harness from the PDC to the fogs, similar to the 2009-2012 truck kit. I have a damaged OEM bumper harness to use as a template.
Just need to knock out a few conversion harnesses first.
M² Mods - From my non Flammable S7!
Ram_Fish1
Indiana
2013 BigHorn CC 4x4
5.7L
If you really want one, I can make it (@$100). I have made two so far for members. You just need to check all four connectors in your truck to make sure it will work for you and still buy a few items for inside the tailgate. It may not make financial sense vs buying the full Mopar kit unless you want the same wiring as a factory truck.
Was hoping to buy mopar kit and just need section between radio and harness near brake pedal, to keep from tapping bcm, but maybe that's not how it works. Will be in touch with email and pm, like to do backup cam and finish 4 speed to ra4 bezel swap all at once. Thank you sir
Mpgrimm2
Mpgrimm2
SC
5.7L
The two wouldn't work together, just completely different concepts, but ...
Depending on what your truck has from the factory, it's possible that you have a partial camera harness in your truck (seems to mostly be a 2500+ thing). Your could check the 4 connectors on your truck to confirm if you have anything at all.
Here's a good starting point...
backup camera thread Post 14
Post 250 & Post 694
Hey Grimm, I know I could read and try and figure out but is this a portion of the jeepguy harness (I used on my first swap). Are you on the trail of recreating that?
After going that route, the Mopar kit is hard to consider isn't it?
VLG6963
