multifunction switch going bad?
bigtigga84
dela....where?
So the other night on the way home, I had the high beams on and a car was comin so I clicked em off...... but they didn't go off. Had to pull off and click the switch a couple times to get them to go off. Little farther down the road and a couple times since, I'd go to turn the highs on and they wouldn't stay on. Had a similar issue with the exploder I had, but had no headlights at all unless I held the switch in. Something else weird goin on is the low windshield wiper fluid light comes on every time I drive, but there is plenty of fluid and the plug is secure.
RubberFrog
Sounds like you need to replace the stalk. Have fun with that....
As far as the washer fluid- you just need to clean the sensor.
bigtigga84
bigtigga84
dela....where?
10-4 on the sensor. Is replacing the stalk really that bad. Had the column spared on the slpoder and it didn't look that bad. I know its a completely different vehicle.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I will ask my bro if there is anything in all data bout it for ya.
