DRkNESS
- Apr 24, 2012
- 5,808
- 3,393
- South Jersey
- 2019
- 5.7 HEMI
Honestly I've owned my truck since 2010 and have never used the cruise control.
I read from the site, PC disabled when using cruise control.Drkness, how does the pedal commander affect the cruise control? Is the cruise still gradual and smooth?
Almost the same but PC is user friendlyAnyone know how the Pedal Commander compares to the BD Throttle Booster?
I'm sure the BD solution does the same as Pedal commander. I went with Pedal Commander because of the wider range of settings. It is easier to adjust too, simple buttons. The BD unit, you have to open and set jumpers for range, or buy a knob.
I highly recommend for anyone with a diesel. Even if your NOT into performance. Just the improved driveability makes it worth it.
Cruse control question: I use Cruse control on long drives, and seems it is affected by the commander.
How exactly does the cruise seem affected? This is a concern for me, because I do use my cruise control often.
There are a couple of older threads on the pedal commander. One link is below.Will a Diablo tuner work the same as the Commander (throttle performance wise)?
