Frame swap
Micchi
West Lawn, PA
5.2L
So I decided to do something crazy. Since my current frame is rotting away, I'm going to attempt to swap everything over to the new frame.07876e433d549d056646d2d2480faa49.jpg
Sent from my SM-G920P using Tapatalk
02ramboi
live oak florida
4.7 v8
Good luck looking forward to seeing finished product
Micchi
Micchi
West Lawn, PA
5.2L
Had for about a month and trying to get everything disassembled and sanded so I can paint it with Chassis Saver.
Made myself a shelter so I can work in bad weather. So far it's done a good job keeping the rain out and the dirt in.6b2503d59e0bdbf1144e6edb1ad1605e.jpgecedb74547e4dc859cac64e991e5fd3b.jpg
02ramboi
live oak florida
4.7 v8
Nice looks good. I'm sure it's going to be a fun project
Micchi
Micchi
West Lawn, PA
5.2L
Found out some good news when taking apart the axle. This frame was from a 2000 and not a 99 like I was told. So much to my surprise I have dual piston calipers.
The lower control arms were the only difficult part so far. Wasn't expecting them to put up a fight but, in the end I won...with a cut off wheel7c001d5ed081a7217df1b751d3934224.jpg4248814b19464a38a6b43e0e2120ae62.jpg110bca86cb0883df0237081c3bb19825.jpg
Micchi
Micchi
West Lawn, PA
5.2L
Think she'll be my helper for most of this. Already have her using the impact.48844854b5932b9a12989578e2a2b024.jpg
02ramboi
live oak florida
4.7 v8
Haha when I'm working on mines my mines are always asking can I help let me do something lol teach them young
Micchi
Micchi
West Lawn, PA
5.2L
So for some reason Dodge decided that this 1 part of the coil spring mount needed to be solid. The other side and the rear part of the mount are open to allow water and dirt to fall through. When I cut into it there was about 2 inches of dirt built up.
Cleaned it up and welded the inner edge.d981972a30b3f5208d82225ad00f9fd3.jpgf0f01d6bb4757052a9d1ceacb6c9b300.jpgf2c0062daa3002d3aa4604c398853e9c.jpg3848fd47a7212e7e4a237f5a94d1a013.jpg
Micchi
Micchi
West Lawn, PA
5.2L
The brakes look like they've barely been used. I'm conflicted because there's a part of me that wants to replace everything but the other part of me says to save the money and reuse the brakes.2bffd352f90b6922278f90144d2f96b8.jpg796e4f54691e9fd588a682bdd95eec13.jpg8ba78d735d2ae18155719bbc65450b39.jpg
02ramboi
live oak florida
4.7 v8
That's a very tough decision I did that one time with my brakes and I had to end up going back afterwards and replace but yours look ok
aheeejd
4.7 V8
What an awesome project. I have a 03 Ram with a 4.7 that died. 240 k, I bought remanufactured & dropped it in. My frame is ok cause the last several years I had it hot oil undercoated. Guy in my area makes a hell of a living in his garage doing this. Funny, now that the motor is all in (finished installing last Dec) & running great, I'm bored. Like I want to be wrenching on the truck. Following this thread will have to suffice
Sent from my Nexus 6P using Tapatalk
Micchi
Micchi
West Lawn, PA
5.2L
Made a little progress, need to get the ball joints out and clean up for paint.81b1f9a13e3ee26ad2ef9bbcd5c1ca70.jpg
Micchi
Micchi
West Lawn, PA
5.2L
So I'm considering putting a limited slip in the rear but I have no experience driving with one and don't know if it will be worth the cost and hassle.
crazykid1994
Florida
Limited slip drives the same. I have a 97 with open diff and my 17 has limited slip. No difference driving except my 97 feels like a brick driving down the road :p if you do any off-roading or anything I would look into a Detroit diff since it's not clutch packs. Less likely to dig yourself into a hole if you go onto sand as well from one tire spinning.
Micchi
Micchi
West Lawn, PA
5.2L
Don't have any plans to go off road. I didn't know if it would be beneficial in the snow or not.
crazykid1994
Florida
I can't say as it would help or hurt in the snow. Never driven in the snow myself as I'm in Florida...
crazykid1994
Florida
Well I might be doing this same thing you are. My 97 has some rot to it. Might be looking at a 98 to use as a parts truck. :)
R/T_Fire
Pleasant Grove
For the snow yes... the more wheels that give power to the ground the better.... I'd say its worth the expense..
But looks like a fun project... it will be a "brand new" truck when your all done
dudeman2009
Magnum 360
My personal opinion, good tires did more for me than fixing my limited slip diff. If you're going to spend aprox $300 on a LS diff, why not just bump it up to $600 and get yourself an eaton locker that will do wonders in the snow.
austmurr
